Thread: Spark plug gap question
Results 1 to 19 of 19
  1. #1 Spark plug gap question
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    Just got new wires and autolite xp606's. I'm hearing stuff from people saying dont gap them or something and i honestly have no idea what that means. Somebody help me out here cause i'm now confused
  2. #2 Re: Spark plug gap question
    gap them to .055 or something around that
  3. #3 Re: Spark plug gap question
    Ohio
    stock is around .055-.060
    They're iridium.
    You can very easily trash them when trying to gap them.
    If this is for a gt gap at 0.060.
    If this is for a gtp, return them and get ap606's and gap to 0.060 if stock, 0.055 for a 3.4
  5. #5 Re: Spark plug gap question
    Pennsylvania
    Quote Originally Posted by GTLGDP View Post
    Leave the gap at 0.60. It's already set - that's why they come with those plastic sleeves on them. You don't have a racecar that's going to blow out the spark when the gap's too big. So don't pretend like half the people here.
  6. #6 Re: Spark plug gap question
    GTP Level Member 1ATony's Avatar
    mass
    If the car's pretty much stock just stick with a decent replacement plug.
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  7. #7 Re: Spark plug gap question
    Oct 2011
    New Jersey
    So these are pre-gapped? I call my buddy whos changing them for me and he said usually the good ones are pre-gapped.
  8. #8 Re: Spark plug gap question
    mass
    They could be. Even if they are I always double check them with the plug gapper just to make sure.
    Tony
    1aauto.com
    SALES 888-844-3393
  9. #9 Re: Spark plug gap question
    Pennsylvania
    I know for a fact that GM plugs are pre-gapped. Not 100% on AutoLite or NGK. They should be pre-gapped, though, because they are iridium. If they came in a plastic sleeve, they're pre-gapped.
  10. #10 Re: Spark plug gap question
    Oct 2011
    New Jersey
    They didn't come in a plastic sleeve, they came in a box of four, then inside the box was 4 individually boxed spark plugs with nothing but the plug inside
  11. #11 Re: Spark plug gap question
    Pennsylvania
    Hm. Last set I did had a plastic tube over the threads, inside a bos, inside a box with more boxes of tubed plugs. Wouldn't hurt to use a feeler gauge to check them... little more expensive than the coin type used for copper plugs, but will have a pulling tool to make larget gaps (really, could just pull with a pice of wire, though)
  12. #12 Re: Spark plug gap question
    Pennsylvania
  13. #13 Re: Spark plug gap question
    Oct 2011
    New Jersey
    Changed the plugs, car runs great now but i am gonna put Lucas injector cleaner in there just to make sure.
    There was oil on the old plugs..Uhh..****? Is this just the valve cover leaking or something?
  14. #14 Re: Spark plug gap question
    Pennsylvania
    In the business end? Or just the outside?
  15. #15 Re: Spark plug gap question
    On the outside of the plug or on the tip of the plugs thats in the head?
    You could have some blow by or leaky valve seals, maybe change your PCV valve, it might not be working 100% correctly, its a $3 part.
  16. #16 Re: Spark plug gap question
    Oct 2011
    New Jersey
    It was around the tip thats in the head, is this a big problem?
  17. #17 Re: Spark plug gap question
    Oct 2011
    New Jersey
    What the ****?!?!? I reset my trip counter after I got them changed and not even ****ing 40 miles later its doing it again. Blinking light and all. Wtf now
  18. #18 Re: Spark plug gap question
    Figure out which cylinder(s) it is.
    Swap a coil if needed, see if it follows.
    If not fixed then, burn the car to the ground or buy a new ICM.
  19. #19 Re: Spark plug gap question
    Oct 2011
    New Jersey
    This is such bull**** my car has been nothing but problems. I'll get back to here sometime tomorrow after i call numerous places for information.
  1. PCM and spark plug question
    By jjwalton77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2011, 05:31 PM
  2. Spark Plug Question.
    By DnaProdigy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2011, 09:45 PM
  3. yes another spark plug question...
    By jayn in forum General Tech Discussion
    Last Post: 03-22-2011, 09:09 PM
  4. Spark plug question
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2011, 03:44 PM
  5. Spark plug question
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2008, 05:36 PM
