Thread: 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
Results 1 to 13 of 13
  1. #1 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    Jun 2011
    waterford mi.
    What tool do I use?
  2. #2 Re: installing new fuel pump...
    mike, i think we need a tad bit more info. thanks. like what part are you removing? out of the tank, the pump from the sender?
  3. #3 Re: installing new fuel pump...
    Ohio
    your taking a snap ring off.
    unhooking lines.
    unplugging connectors.
    pulling the assembly out, dropping new one in.
    push it down and hook the lines back up.
    shove it down and slide the closed end of the snap ring in the back lips adjacent to the fuel lines.
    walk the rest of the snap ring in.
    plug the connectors back in.
    snap the fuel lines on and start it up
  4. #4 Re: installing new fuel pump...
    read this thread its got a vid how to remove it. http://www.grandprixforums.net/no-st...ump-60730.html
  5. #5 Re: installing new fuel pump...
    Ohio
    i use a couple 90* picks
    screwdriver
  6. #6 Re: installing new fuel pump...
    Sep 2011
    Arkansas
    Did mine with a pocket knife and a flathead.
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  7. #7 Re: installing new fuel pump...
    Jun 2011
    waterford mi.
    The hole pump. but i didnt see a snap ring or anything.i know it has to turn but i didnt want to use a screw driver in fear of sparking something.
  8. #8 Re: installing new fuel pump...
    Ohio
    lol dude youll be fine.
    chip away the rust and youll see the snap ring
  9. #9 Re: installing new fuel pump...
    Jersey
    i used a 90* pick tool
    16' wrx sti- stock
  10. #10 Re: installing new fuel pump...
    Jun 2011
    waterford mi.
    I dont have any rust on, it never been in bad weather or salt, clean as a whistle. looks like the pump just turns out? --does not have a snap ring ??
  11. #11 Re: 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    Portland Oregon
    Seriously guys? Stop confusing him. There is no snap ring on cars with plastic tanks. I.E. 01+.
    OP, You need to take a flat screwdriver and hammer (after disconnecting the fuel lines and electrical connectors) and drive the retention ring counter clockwise until it's free. Don't worry about sparks, you'd have to really try to get one. I bang on these rings pretty hard.
  12. #12 Re: 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    Jun 2011
    waterford mi.
    Thats what i did.came out pretty easy but going back was a little tricky. but it is in and running good happy happy happy thanks for all the info.
    Ohio
    Oops sorry lol I forgot about the plastic tanks
  1. Son of a... installing fuel pump canister. Need help!
    By Agentlongwood in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2012, 01:33 AM
  2. Fuel Filter and Fuel Pump 04 Grand Prix!
    By bjornbjorn in forum General Tech Discussion
    Last Post: 04-12-2011, 12:26 PM
  3. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
  4. Installing a Water Pump in an '03 GP SE?
    By sb76 in forum General Tech Discussion
    Last Post: 12-23-2010, 11:38 AM
