Thread: Son of a... installing fuel pump canister. Need help!
Results 1 to 9 of 9
  1. #1 Son of a... installing fuel pump canister. Need help!
    SE Level Member Agentlongwood's Avatar
    Nov 2009
    Orlando
    So the oring that ZZP sent me to seal the fuel pump canister in the tank failed and I got a new one from advance auto. It is noticeably thicker which sounds awesome, hurray it should seal properly. But I cannot for the life of me push the freaking canister down hard enough to get the snap ring to slip under the tabs that hold the whole setup in place. Is there a trick to this? I'm bout to break my thumbs pushing down on this bastard.
  2. #2 Re: Son of a... installing fuel pump canister. Need help!
    Apr 2009
    Fort Worth TX
    Same problem here when I replaced my pump. I used a 2X4 and my foot. Put some lube on the snap ring.
  3. #3 Re: Son of a... installing fuel pump canister. Need help!
    Nov 2009
    Orlando
    My tank is in the car and Im sitting in the back seat doing this. I'm trying to picture how you got your foot up in that little gap between the seats lol. Thanks for the input though. Any other ideas or tricks out there?
  4. #4 Re: Son of a... installing fuel pump canister. Need help!
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by Agentlongwood View Post
    Glad you got it. I almost gave up when doing mine.
    I was sitting in the trunk of the car.
    Ohio
    Shove it down as far as you can, then slip the closed end of the snap ring in under the lines. Shove it more while you walk the rest of the ring in.
  6. #6 Re: Son of a... installing fuel pump canister. Need help!
    Nov 2009
    Orlando
    I got the bastard. I did basically what you were saying. I got the ring under one clip, then pushed like a mofo on the edge with a peice of wood and then with a claw hammer with the claw tucked under the sheet metal. What a pain in the ass lol. Thanks for the help guys I appreciate it.
    Ohio
    Haha good ****. I've done it so many times now I could probably do it with one hand its not leaking now is it?
  8. #8 Re: Son of a... installing fuel pump canister. Need help!
    Nov 2009
    Orlando
    The seal looks to be holding. I went to fill it up and nothing poured out. I drove home "spiritedly" to try to get the fuel to slosh around and nothing ran out the top. I think I'm good. If this seal ends up failing I WILL most likely shed tears.
  9. #9 Re: Son of a... installing fuel pump canister. Need help!
    Ohio
    nahh it shouldnt. at least you know that the oring was the problem. i figured it was
  1. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
  2. Installing a Water Pump in an '03 GP SE?
    By sb76 in forum General Tech Discussion
    Last Post: 12-23-2010, 11:38 AM
  3. Racetronix Fuel pump canister install questions...
    By Iron Indian in forum General Tech Discussion
    Last Post: 05-18-2009, 12:11 AM
