Thread: Need Help With No Spark!
Results 1 to 17 of 17
  1. #1 Re: Need Help With No Spark!
    Make sure the ICM ground is hooked up.
    It could be a faulty Cam or Crank sensor causing this too.
  2. #2 Re: Need Help With No Spark!
    Oct 2011
    Puyallup WA
    I found what I think is the ground wire for the ICM...was a wire running out of the bundle that goes towards the ICM and it it bolted under the snout down towards the block...it seemed to be intact...also could a brand new crank sensor be bad...I already changed the crank sensor...also will they throw a code if either crank or cam sensor is bad because I have no codes for either
    08 G8 GT - exhaust Tune
  1. 08 with no spark
    By JJB in forum General Tech Discussion
    Last Post: 03-28-2012, 10:27 PM
  2. No spark HELP!!!
    By Machzzzz1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2010, 12:30 PM
  3. 72 gp sj no spark
    By rayzo63 in forum General Tech Discussion
    Last Post: 02-16-2009, 10:40 PM
  4. Spark
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-14-2008, 04:06 PM
  5. no spark
    By faboskay57 in forum General Tech Discussion
    Last Post: 07-10-2008, 07:41 AM
