the 970-044 do not work. i removed all the wheel harnesses front and rear (yes the rear can also be discounted were the trailing arm mount to the frame). i used an ohm meter to check resistance or wire breakage. all the harnesses gave the same resistance. i put dielectric grease on them and reinstall. its been two weeeks and the light yet to return. it seems like the grease fixed the problem.
