Thread: Core Support
Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
  1. #21
    St louis
    Would bending his frame back into place be an issue with traction? His front tires are pretty bald
  2. #22 Re: Core Support
    Jan 2012
    Philadelphia
    depends on how you do it on a frame rack it will give it a pull. the car has frontal collision so when it was hit impact traveled through the vehicle, you want to reverse that impact to get the car to pre-accident condition. Thats why a frame rack is the best option because you have claps to hold the car in place while it pulls. Instead of pulling in a certain area there may be other spots on the car that are bent but cant be seen. After your repairs you will want to get the car realigned any way to aviod caster, camber and eccesive toe, resulting in traction problems and tire wear.
    GT Level Member boothe's Avatar
    Troy, Mo
    What kind of shop would have a frame rack
    Sent from my Motorola Electrify using Tapatalk
  4. #24 Re: Core Support
    Jan 2012
    Philadelphia
    any high end body/collision shop you can just ask them to straighten your frame and you can do the rest
    Troy, Mo
    Cost range?
  6. #26 Re: Core Support
    Jan 2012
    Philadelphia
    not really to sure to be honest i only have ever worked with them idk the cost range but id say its worth it because you will want your body to be straight to avoid many other problems
    Troy, Mo
    Ya absolutely will that take care of the radiator support or just the frame
  8. #28 Re: Core Support
    Jan 2012
    Philadelphia
    your rad support doesn't look to bad i think that they will be able to straighten it out on a frame rack no problem, ask around and get some different estimates from shops.
    Troy, Mo
    Will do thanks man lots of help
  10. #30 Re: Core Support
    Jan 2012
    Philadelphia
    no problem. let me know if you have any other questions PM me if i don't get back to you in time, glad i could help! and best of luck to you and your GP
  11. #31 Re: Core Support
    St. Louis
    Give SRC Auto Body a call. Also check w/ White Auto Body since they're out in St. Charles area. One of them may have a rack
    Troy, Mo
    Just call I70 auto body there in wentzville they have one said anywhere from 54 to 115 bucks depending on what they need to do
  13. #33 Re: Core Support
    USA
    Thats not to bad.. A good shop will pull that for you.
    Here a few pictures of a 04+
    measuring.. Cars are measured in MM..heres how bad this one was
  14. #34 Re: Core Support
    Yoga city
    damn man if you need a hand im close to ya, guess no meet for you anytime soon
    Troy, Mo
    Ya it sucks man... u do any painting? Lol
  16. #36 Re: Core Support
    Yoga city
    wish i did painting, i need to respray spoiler and trim under the door, damn clear is pealing
    Troy, Mo
    Lol i leave for Texas. May 4th so it will prob be left at a shop to be worked on while im gone prob sd hood and new front clip
    Troy, Mo
    Has anyone ordered front bumper clips off of ebay
    Troy, Mo
    Replaced radiator lastnight now need front clip and hood
  1. Hood lift support? Help..
    By GTLGDP in forum General Tech Discussion
    Last Post: 11-20-2011, 11:04 PM
  2. lumbar support
    By vincegpking in forum General Tech Discussion
    Last Post: 04-07-2011, 06:44 AM
  3. Needs some GPF support and votes!
    By Swash in forum Off Topic Discussion
    Last Post: 10-07-2010, 02:58 PM
  4. 2-support Mirrors
    By arc in forum 04+ Specifics
    Last Post: 02-08-2010, 02:42 PM
