Thread: GP Shaking Badly, raspy/loud exhaust. Need help!
Results 1 to 15 of 15
  1. #1 GP Shaking Badly, raspy/loud exhaust. Need help!
    GT Level Member VejGTP's Avatar
    USA
    Hey guys, sorry for making another topic so soon, but my GP is running horribly and I'm hoping someone might be able to tell me whats wrong so I could get it fixed. I'd take it to a shop tomorrow morning, but most of the shops around here charge outrageous prices if you don't know exactly what wrong with your car. I've had bad experiences and I'm hoping to get one step ahead..
    My cat went bad a little while ago and I've been looking into getting new headers or a cat-less downpipe. I don't have the equipment to change headers though.
    ANYWAY, I pulled up to a stoplight on my way home from work (Tuesday night) and when I came to a stop my car started shaking really bad. The lights started dimming and the engine felt like it was going to stall. The exhaust got louder and really really raspy sounding. The car would even act like it wanted to accelerate on it's own.
    Let me specify more about the actual shaking. It's not an issue with the wheels/alignment. The engine/exhaust itself is moving a lot more than it should be while IDLE. If I look underneath the car or at the tailpipes, the pipes are moving/shaking a LOT more than they ever should be, and it's quite loud.
    I really don't know what the problem would be, I'm not really advanced with cars I just know some of the basics. Also, I replaced Vacuum Tree/Intake Manifold Vacuum (Small plastic piece with 2 hoses, near throttle body) Wednesday during the day when I noticed one of the plastic pieces was broken off. I also changed my plugs and wires Wednesday.
    I know that's a lot of reading, but I hope someone can help me with this issue. I would really like to get it to the shop asap or possibly have a friend help me fix it if it's not a HUGE problem. Thank you!
    2004 GTP Comp G. Wizaired CAI
  2. #2 Re: GP Shaking Badly, raspy/loud exhaust. Need help!
    Do you still have a bad cat on the car?
    If yes..then likely it's getting worse and or blew out.
  3. #3 Re: GP Shaking Badly, raspy/loud exhaust. Need help!
    USA
    Yes it's still there, I jacked the car up last night to look for any serious problems and I didn't see any holes or anything on the cat (but it does still need replaced.)
    Do you think removing/replacing that would fix this problem?
  4. #4 Re: GP Shaking Badly, raspy/loud exhaust. Need help!
    I'd think that fixing a known issue, might help.
  5. #5 Re: GP Shaking Badly, raspy/loud exhaust. Need help!
    USA
    Well of course, I'm not against fixing the cat, I just wasn't sure if there might be other reasons it would be doing this.
    I guess my next question is would installing a new cat be fairly easy by myself? I heard zzp has them but I was hoping for a bolt-on, so I could save some time.
  6. #6 Re: GP Shaking Badly, raspy/loud exhaust. Need help!
    The equivalent of what your car is going through right now..would be someone putting a supersized cork up your butt and making it so you can't pee. Then...someone keeps feeding you. You'd be shaking and acting funny too.
    Likely your entire problem is a plugged cat and hopefully....not a negectful owner.
  7. #7 Re: GP Shaking Badly, raspy/loud exhaust. Need help!
    USA
    Well I knew my cat was starting to go bad, but I planned on just replacing it with a cat-less downpipe. Unfortunately I've only got one friend that can help me and he has been very very busy lately. I don't know any other mechanics or shop owners/workers. I just would rather change the cat myself if it's not too difficult, instead of paying a few hundred dollars.
    I love my pontiacs and I hate seeing them like this .
    What would you suggest for a replacement bolt on cat?
    Thank you for the replies!
  8. #8 Re: GP Shaking Badly, raspy/loud exhaust. Need help!
    USA
    Hm?
  9. #9 Re: GP Shaking Badly, raspy/loud exhaust. Need help!
    Apr 2009
    Fort Worth TX
    ZZP aluminized downpipe with catalytic convertor. Mine was about $200...can't remember if I got the gasket option.
    I think there's only 5 bolts and a rear O2 sensor. You may need some deep-well metric sockets to remove the 3 nuts from the manifold as they are studs.
    It took me about 20 minutes and there was a beer or two in there somewhere.
  10. #10 Re: GP Shaking Badly, raspy/loud exhaust. Need help!
    USA
    Ah so they are bolt-on if you get the downpipe with it? Sorry for the stupid questions, I'm new to exhaust work.
  11. #11 Re: GP Shaking Badly, raspy/loud exhaust. Need help!
    Apr 2009
    Fort Worth TX
    Yea, ZZP refers to it as "bolt in with cat". It comes as one piece and they've also welded the O2 bung in place.
    The other thing they do is delete the U-shaped section right before the cat-back. This frees up some flow.
  12. #12 Re: GP Shaking Badly, raspy/loud exhaust. Need help!
    USA
    Gotcha. Hmm I thought 04+ didn't have the u-bend?
  13. #13 Re: GP Shaking Badly, raspy/loud exhaust. Need help!
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by VejGTP View Post
    Maybe so. Mine are 2000GT and 2002GTP and they both had the U section.
    You know if you're up to the challenge you can weld a Magnaflow in there (since you don't have a u-bend). It's fairly easy.
    I did one of catalytic convertors on my Mirage (it has 2)...cut old cat out with a Sawsall and loosened the bolts. There was enough play in the exhaust to wiggle the new cat in place and tightened the bolts back up. After three spot welds I dropped the entire pipe and welded it the rest of the way on the bench. My cheap flux-core welder worked real well.
  14. #14 Re: GP Shaking Badly, raspy/loud exhaust. Need help!
    Pennsylvania
    Correct.
    W-Body Store prices are usually volleying back and forth with ZZP. Might be cheaper for the same thing.
  15. #15 Re: GP Shaking Badly, raspy/loud exhaust. Need help!
    USA
    Took it to the shop and they said piston 6 is failing. Not sure the exact cause, they are going to look at it further tomorrow. Valve or Head Gasket probably. Either way I'll still get a new cat after that repair is finished.
    Sucks!
  1. Loud exhaust leak!
    By cameron92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2011, 02:59 PM
  2. loud crackly exhaust
    By jcmonteman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-30-2011, 08:30 AM
  3. exhaust loud as hell!!
    By tmackster in forum General Tech Discussion
    Last Post: 03-27-2011, 05:46 PM
  4. need help badly!!
    By Viperhunter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2009, 08:30 AM
