Thread: 92 grand prix stall out.
Results 1 to 5 of 5
  1. #1 92 grand prix stall out.
    Mar 2012
    i have a 92 grand prix. last week it stalled out after a long drive when i tried to take off. it started right back up so i thought nothing of it. now a week or so later this 'stalling" is becoming a huge problem. i almost got into an accident because i tried to take off across traffic "turn left" and it stalled out. i almost got hit before it started back up. after it stalls i have to hold pedal to floor to get it rto start. it coughs and sputters before it goes again. it used to do this(stall) only when taking off from a stop. now it is stalling at highway speeds when given the gas. i think my fuel pump is going out...
    tune up yes. codes no. has 266k miles. runs great 25-26mpg but has developed this stall problem. it will only start back up if i hold pedal to floor when cranking. it used to start right back up but now it takes 5-6 tries before it will stay running. i believe the problem whatever it is has rapidly gotten worse. this is a safty concern for me. the feul low light will go on and off randomly while driving. not sure why. check gauges light will also go on and off randomly
  2. #2 Re: 92 grand prix stall out.
    new britain, ct
    how many miles?
    have you done a basic tuneup recently?
    any codes?
    07 Black GXP.
  3. #3 Re: 92 grand prix stall out.
    Mar 2012
  4. #4 Re: 92 grand prix stall out.
    St. Louis
    Either the fuel pump is dieing, or the MAF is going bad. A bad MAF may not set a code. You can disconnect the MAF and still drive it (gently) and see if it gets better. The only other idea I have is that the Crank Position Sensor is going bad. Do you notice the tach dropping to 0 before it stalls? If so, then this is a tell-tale sign of a bad crank sensor.
  5. #5 Re: 92 grand prix stall out.
    new britain, ct
    at that many miles cleaning your MAF sensor isnt a bad idea anyways.
    and i am thinking along the lines of fuel pump as well...
    07 Black GXP.
  1. 2000 Grand Prix Tachometer/Trac Light/Stall Issues
    By ZackN in forum General Tech Discussion
    Last Post: 09-26-2013, 11:40 AM
  4. Grand Prix GXP exhaust on a standard Grand Prix
    By JenniGP in forum General Tech Discussion
    Last Post: 03-29-2011, 10:15 PM
  5. Will a 04 grand prix 3800 engine fit into a 01 grand prix
    By jordan61488 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-24-2010, 01:01 AM
