Thread: need help badly!!
Results 1 to 8 of 8
  1. #1 need help badly!!
    wisconsin
    ok im having an awful time with my 98 gtp. i have a nasty squeal when the car is running and i cant figure out what it is! i replaced the coupler in the supercharger and that didnt work. i looked at the belt it looks good still tried belt dressing that didnt work. when i take the belt off of the supercharger it makes no noise. put belt back on it sounds awful! please help me could it be bearings in the supercharger? i replaced the supercharger idler pulley to. i have no idea what it can be and it sounds awful so for now im driving the car with the belt off of the supercharger
  2. #2 Re: need help badly!!
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    check the belt tensioner and your other pulleys that r run by that belt. also just cause u sprayed belt dressing on it doesnt mean its gonna stop the squeal, belt might just b that bad. ive had plenty of cars where belt dressing did nothing, sometimes the squeal got even louder.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  3. #3 Re: need help badly!!
    wisconsin
    thats whats happening when i put the dressing on it stops for a second then gets twice as loud...but the belt looks decent
  4. #4 Re: need help badly!!
    make the title of your thread more specific and maybe more people will step in and post. you cant just be like "OMG SOMETHING IS BROKE!".
    also, you only needed to make one post, why did you have to make two?
  5. #5 Re: need help badly!!
    wisconsin
    sorry just trying to get it figured out dont have to b rude i asked for help not to listen to someone that dosent like my post again sorry new to forum just want to get it fixed spent hours yesterday on it cant figure it out very frustrating!
  6. #6 Re: need help badly!!
    take the belt off and spin the blower. can you hear anything besides a little tiny noise (thats normal)? next step is to see if any of the idlers are going out.
  7. #7 Re: need help badly!!
    Jersey
    there is more than just one idler pulley for the s/c, just a thought.
    16' wrx sti- stock
  8. #8 Re: need help badly!!
    wisconsin
    ya i replaced one of the idlers so maybe its the other idk.....i can drive the car with the belt off of the supercharger and i get no noises at all! so its gota be something with either the belt or pulleys? it couldnt be the supercharger itself could it or could bearings or something be bad when the belt spins it? idk tho it dont seem like the blower sounds like a damn belt but the belt looks fine....
  1. replaced power steering pump and now it is squeeling and leaking badly! Help
    By Cheri in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2009, 08:10 AM
  2. Car Vibrating badly
    By bcrosby51 in forum General Tech Discussion
    Last Post: 07-23-2008, 07:52 AM
  3. need your help badly trannyman
    By Zainoman in forum 1984-early 1990's 4 Speed Automatic (440T4)(4T60)
    Last Post: 05-11-2008, 06:28 PM
