Thread: Help
Results 1 to 8 of 8
  1. #1 Help
    Mar 2012
    McCormick sc
    I have a 98 gtp Daytona edition#229. I bought the car used in December 2011. The tcs will not activate and neither will the low trac or the cruise control, are all these connected somehow. Also from a dead stop hard takeoff it will spin the wheel for about 2 secs then the engine dies back to about 1000 to 1500 rpms and will not pick back up until I completely let off the accelerator and them accelerate again. Any and all suggestions would be greatly appreciated.
  2. #2 Re: Help
    St. Louis
    I'd be willing to bet that your TCS is active judging by the wheelspin then the power retard until letting off. The bulb that indicates Trac-Off is probably burnt out. Mine is since I manually turn it off all the time.
    The cruise I would check for blown fuses, and then check the cable under the hood to see if its even attached.
  3. #3 Re: Help
    GT Level Member Toms04compg's Avatar
    Michigan
    Sounds like its active but if your trying to press the trac button and no result check fuse if there is one maybe button. Not sure about the cruise i thought those were more vac.
  4. #4 Re: Help
    Mar 2012
    McCormick sc
    Yeah it's says tcs off all the time and pressing the button beside the light doesn't change it. Does the button on the shifter activate the low trac
  5. #5 Re: Help
    the abs light on too?
  6. #6 Re: Help
    St. Louis
    The "low trac" is just an indicator that lights up when the wheels spin, it is not a feature. I'd be willing to bet that you have a wheel speed sensor that is bad (or hub bearing) and the TCS system is inactive. My 00 GT is like that right now.
    My question is if you stomp the brakes does the ABS work or do your wheels lock up?
  7. #7 Re: Help
    Mar 2012
    McCormick sc
    Yes my abs light is on. I found on zz performance a module I can wire in that when the vehicle is started the tcs automatically goes to a default off position. Would that be a good buy. Also what is the button on the shifter as when I press it nothing happens.
  8. #8 Re: Help
    when the abs and trac off light come on usually it means you have a bad hub/speed sensor in the hub.
    do what fordman said, and check back. abs should not work, and the trac control should not work either. but things happen.
    that small button on the shifter is the performance shift button. it changes how your trans shifts. it should light up on your dash, maybe the bulb burnt out for it.
