Thread: so frustrated with this car
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 99
  1. #1 so frustrated with this car
    new york
    this car is acting up again the more i take care of it the more it acts up misfire on number 3 now new plug wire coil pack i dont understand, just idles ruff but it runs great driving down the road
  2. #2 Re: so frustrated with this car
    Ohio
    do you have those metal sleeves around the spark plug wire boot? if so, take them off. they do more harm than good in some cases.
  3. #3 Re: so frustrated with this car
    new britain, ct
    alright. start at the top. you got new plugs? what did you get?
    07 Black GXP.
  4. #4 Re: so frustrated with this car
    Some NGK plugs have screw on pieces where the plug wire makes contact. If you have screw job NGK's consider changing them. This was a pain to find when it happened to me.
    What brand plug wires?
    If all else fails, I've seen a bad ICM not fire one plug. Ensure that both coil towers are throwing spark. That would indicate a possible bad ICM if everything else is good.
    Lastly.. have any plugs ever come out of the cylinder with any damage? .
  5. #5 Re: so frustrated with this car
    new york
    well the plugs i got were autolites, wires were from autozone lifetime warranty and the metal sleeves are off, and the number 3 cyclinder one had no end like the small metal thing on the end was off but i wasnt sure it was like seeing i dropped it befor i could inspect it, and theres spark coming from the coil both sides, i took the plug out again after running it for a while and it seems good no damage
  6. #6 Re: so frustrated with this car
    Pennsylvania
    Quote Originally Posted by kawasakidrivinghick View Post
    Oh dear. That part is important.
  7. #7 Re: so frustrated with this car
    new york
    what it mean it i was like that?
  8. #8 Re: so frustrated with this car
    Apr 2009
    Fort Worth TX
  9. #9 Re: so frustrated with this car
    new york
    thats about how i feel
  10. #10 Re: so frustrated with this car
    SE Level Member 1999GrandPrix's Avatar
    Oct 2011
    South Carolina
    autozone wires are prolly ur problem. also if they are new try rerouting them. i mean from the coils then under the dogbone (not through the bone) and then to the cylinders. appparently the route of the stock wires were horrible lemme know if that works
    1999 GT
  11. #11 Re: so frustrated with this car
    new york
    its just number 3 cylinder
  12. #12 Re: so frustrated with this car
    Texas
    Have you checked the number three fuel injector yet?
    85 Corvette
    01 TA
    03 Z06
  13. #13 Re: so frustrated with this car
    new york
    no i havent how i check em?
  14. #14 Re: so frustrated with this car
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    That guy prolly needed the installer mod.
    lmao
    To add, I use autozone wires on TONS of 3800's.
    that reminds me. are you talking about duralast? cuz those arent the BEST but they arent bad either. ive had plenty of good experiences with them.
  15. #15 Re: so frustrated with this car
    Swap the #1 and #3 injector on the fuel rail and see if the problem follows the injector to cylinder #1.
    They are great wires, 30 bucks...lifetime warranty.
  16. #16 Re: so frustrated with this car
    ^^^^^^^^ Could try that or swapping coils to see if the miss fire changes cylinder number too.
    I have never in my life seen fuel injector cleaner do a thing as far as having a misfire light on waste IMO.
    Miracle in a bottles are 90% the time a joke.
  17. #17 Re: so frustrated with this car
    wouldnt a clogged cat problem get worse under load as the cars trying to get rid off more exhaust rather than idleing nope doesnt seem like an exhaust problem to me either.
    Missfire still makes me believe its in the ignition system..............
  18. #18 Re: so frustrated with this car
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    She said it smelled funny, which is why I asked about the cat.
  19. #19 Re: so frustrated with this car
    Dude im not trying to argue with you so chillax,
    If your actually driving its producing more exhaust than at idle and it was already stated that the car runs worse at idle so problems at a lower rpm rather than actually driving the car would make me highly doubt its anything to do with the exhaust.
  20. #20 Re: so frustrated with this car
    btw a bad cat would likely cause RANDOM misfire across all the cylinders rather than just one trust me ive had a 02 with a bad cat and it was throwing egr codes too and it was getting super hot.
  1. need some help. Very frustrated
    By mainjet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-12-2011, 07:58 AM
  2. Frustrated 4t65E trouble
    By Gman in forum The Rant Forum
    Last Post: 05-24-2009, 12:47 AM
  3. Frustrated in NC
    By Gman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2009, 10:28 PM
  4. FRUSTRATED ..trying to buy
    By Ninjo in forum The Rant Forum
    Last Post: 07-01-2008, 05:56 PM
  5. electrical? I am frustrated!
    By smitch in forum General Tech Discussion
    Last Post: 06-23-2008, 11:02 AM
