Thread: car dies when i let off the gas at low speeds
Results 1 to 6 of 6
  1. #1 car dies when i let off the gas at low speeds
    Jan 2012
    goodland, in
    so i finally got the car to run right but when im going about 20mph or backing up or anything like that where i just have to tap the gas and it will bog down and want to and sometimes die i put it back in park or neutral and it fires right back up and goes down the road like a top anybody gota clue or suggestions any help would be great thanx
  2. #2 Re: car dies when i let off the gas at low speeds
    Any codes?
  3. #3 Re: car dies when i let off the gas at low speeds
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    does the engine speed bounce up and down when you start it?
  4. #4 Re: car dies when i let off the gas at low speeds
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    vacuum leak? maf bad?
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  5. #5 Re: car dies when i let off the gas at low speeds
    Jan 2012
    goodland, in
    havent had the chance to check for codes yet so will post when i do and no the engine idles smooth when its running and no vacuum leaks
  6. #6 Re: car dies when i let off the gas at low speeds
    I'd clean the IAC and MAF
  1. Car dies at idle or low speeds
    By mikejon in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-17-2013, 10:44 AM
  2. Scraping noise at low speeds.
    By Bedwards in forum General Tech Discussion
    Last Post: 09-04-2011, 03:48 PM
  3. 95 GP Shudder at High Speeds
    By TheDude in forum General Tech Discussion
    Last Post: 04-15-2010, 10:00 AM
  4. Lost all Heater Fan speeds
    By SuperChargedGTP in forum General Tech Discussion
    Last Post: 07-24-2009, 07:37 AM
  5. vibration at highway speeds
    By dagger in forum Brakes/Suspension/Chassis
    Last Post: 05-25-2009, 07:42 PM
