Thread: Second Theory on why gas milage is bad.
Results 1 to 5 of 5
  1. #1 Second Theory on why gas milage is bad.
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    I'm thinking that my catalytic converter is starting to plug up. WOT in first it will just touch 5500k before it shifts. and in second it doesn't even touch 5K. So i'm thinking possible a clogged cat.
    could this be causing my 120 mile/tank loss?
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  2. #2 Re: Second Theory on why gas milage is bad.
    Mar 2012
    alabama
    Did u lose power to if so i would change the coil pack had mine burn a half a tank in
    a 100 miles th
    ought maybe the converter but wasn't the coil pack was the problem
  3. #3 Re: Second Theory on why gas milage is bad.
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    Quote Originally Posted by BlackGT97 View Post
    your car is showing no other symptoms then this???? there are multiply reasons a car could get bad gas mileage but almost all come with symptoms a driver can either smell or feel. having no syptoms is also a clue but you need to be far more detailed in your post on what exactly is going on if you want us to help. if this is your second thread on this issue post back to the original or copy the original posts syptoms here. your shifting isnt the problem though. your shift is controlled by your computer wich is set up to shift your tranny at different speeds or rpms depending on how hard your pressing the pedal.
  4. #4 Re: Second Theory on why gas milage is bad.
    put your car on some ramps or up in the air high enough, so you can bang on your cat, when your car is cold of course. if you hear rattling your cat is bad. you can use the palm of your hand to hit the cat.
  5. #5 Re: Second Theory on why gas milage is bad.
    HUDSON
    If you have a theory, you have to test your theory, and you must fisrt have a hypothosis, then thest your hypothosis with an expirement, then draw a conclusion.
    In your case you theorise your cat is bad, and you can test this by looking inside. Experiment: drop exhaust after cat and look inside, if cat is bad replace, if cat is good, move to next theory.
    Now, if your cas is bad, you have to find out why it went bad. Unless a cat is manufactured defective, the only way for it to malfunction is with somthing wrong upstream in the exhaust.
  1. theory on why gas milage is bad
    By BlackGT97 in forum General Tech Discussion
    Last Post: 03-17-2012, 11:14 PM
  2. Stoich AFR by Octane Theory
    By Explicit_Spade in forum PCM Tuning
    Last Post: 01-07-2012, 09:37 PM
  3. Replies: 7
    Last Post: 10-05-2011, 06:51 PM
  4. Theory of a Deadman...
    By Lsick7 in forum The Rant Forum
    Last Post: 07-25-2011, 07:26 PM
  5. theory of a deadman = good music
    Last Post: 12-16-2008, 11:23 PM
