Thread: no thermostate and still hot
Results 1 to 16 of 16
robert36482 no thermostate and still hot 03-18-2012, 05:33 PM
gtpeddie Re: no thermostate and still... 03-18-2012, 05:35 PM
robert36482 Re: no thermostate and still... 03-18-2012, 05:40 PM
robert36482 Re: no thermostate and still... 03-18-2012, 05:37 PM
robert36482 no therm and still hot 03-18-2012, 05:59 PM
Scottydoggs Re: no therm and still hot 03-18-2012, 06:04 PM
gtpeddie Re: no thermostate and still... 03-18-2012, 06:21 PM
Fivefingerdeathpunch Re: no thermostate and still... 03-18-2012, 06:46 PM
robert36482 Re: no thermostate and still... 03-18-2012, 07:15 PM
Scottydoggs Re: no thermostate and still... 03-18-2012, 06:48 PM
dsmuts Re: no thermostate and still... 03-18-2012, 06:50 PM
Fivefingerdeathpunch Re: no thermostate and still... 03-18-2012, 07:18 PM
robert36482 Re: no thermostate and still... 03-18-2012, 07:41 PM
copgtp You do understand that... 03-18-2012, 07:45 PM
RooK Re: no thermostate and still... 03-18-2012, 08:42 PM
SlowNA06 Re: no thermostate and still... 03-19-2012, 11:47 AM
  1. #1 no thermostate and still hot
    Mar 2012
    alabama
    going on down the road it runs at maybe 110 when it is really cold out stays on 100 heater does not get hot but in stop and go it will go to 210 r a little higher and heater kicks butt if it has no therm should'nt it stay in the low 100's if i direct wire the fans it never goes higher than 125 in stop and go. what is up with that????
  2. #2 Re: no thermostate and still hot
    Jan 2012
    Philadelphia
    how do you know if its 100, 110 or 125 do you have a water temp gauge? the stock temp gauge starts at 160
  3. #3 Re: no thermostate and still hot
    Mar 2012
    alabama
    my 97 grandprix gt starts at 100 and goes to 210 then 260 thats the only numbers on it i just guess at 125
  4. #4 Re: no thermostate and still hot
    Mar 2012
    alabama
    bought it 6 months ago been like this the whole time i have put 20,000 miles on it .could it be the head or intake gaskets? have herd if no therm is used it will run hot. is that true ?
  5. #5 no therm and still hot
    Mar 2012
    alabama
    going on the highway the temp stays a little above 100.sitting still it will go up to 210 or a little higher and fans kick.on drove 600 miles on the interstate never got much above 100 what's up with that? thought if no therm was in it would stay in the low 100's no matter what. heater works very well in stop and go traffic not so good on a really cold morning on the highway. is it the head/intake gasket's
  6. #6 Re: no therm and still hot
    thats what these cars do, my regal runs at my 1/4 line all day driving, if it sits idling it will hit the 1/2 way mark, then the fans come on, and thats as high as it goes. drive it and it drops back to a 1/4.
  7. #7 Re: no thermostate and still hot
    Jan 2012
    Philadelphia
    replace your coolant elbows idk if they would cause it to run hot but they will go soon if never replaced are you using dex-cool? b/c dex-cool eats away at the gaskets and stuff my temp if all over too try and replace your tstat and see what happens
  8. #8 Re: no thermostate and still hot
    Sorry.
    But I didnt understand a single ****ing word you said.
    So you are running this car with no thermostat????
    The first line can be 100 or 160. The second notch up from the at 195ºish , then its 210 and 260.
    If you are running this car with no thermostat, you are dumb. Put a theromstat in there.
    otherwise flush the cooling system, throw a 195º thermostat in there, and bleed the air out of the cooling system and be done.
  9. #9 Re: no thermostate and still hot
    Mar 2012
    alabama
    why dumb? it gets so damn hot without one sitting still and i get 27 mpg would like to make it rite i am thinking it should not get that hot without one but it does to the point where it wants to boil..new water pump also
  10. #10 Re: no thermostate and still hot
    ^^^yeah, what he just said X 100^^^
  11. #11 Re: no thermostate and still hot
    Just so you know you can't really go by what the gauge says here is mine at 180*
  12. #12 Re: no thermostate and still hot
    Define hot?
    You know reaching 210 is not hot right?
    You know coolant wont boil till over atleast 250º right?
    Fans come at 214 and 226.
    Heat soaking is 100% normal when sitting in traffic.
    Run a 195º thermo, bleed the cooling system of air and the car is function like it should.
  13. #13 Re: no thermostate and still hot
    Mar 2012
    alabama
    did not know that thanks
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    You do understand that running without a thermostat doesn't allow your coolant to efficiently transfer heat right.......you are consistently circulating hot liquid...
    Wow, just wow.
    Sent using my bionic thumbs from my sweet DROID Razr Maxx
    For all your 3800 needs:
  15. #15 Re: no thermostate and still hot
    GT Level Member RooK's Avatar
    Apr 2008
    Southern KY
    Just to make sure... you are running coolant in the system at a 50/50 mix right? Running pure water or pure antifreeze actually affects your temps in a negative way. Antifreeze raises your boiling point, while water is better at heat transfer.
    '13 Stang - V6 MT82 - GHIG
    '00 Grand Prix SE - Pink (L67 Swapped/XP Cam/3.25")
    '98 Grand Prix GTP - Black ($500 toy with broken trans. )
    '01 Bonneville SE - Sitting on a hillside needing attention
  16. #16 Re: no thermostate and still hot
    Pennsylvania
    You trying to chip a piston? Knock sensor doesn't turn on until you hit 160*F. That means if there is a knock condition, there will be no correction for it and you will get detonation. I recommend a stock thermostat.
  1. Broken Thermostate Bolt & small coolant leak ?!?!?
    By FlaminWhite97GTP in forum General Tech Discussion
    Last Post: 02-15-2010, 07:32 PM
