Thread: My car starts up, runs, then dies. Please help
Results 1 to 20 of 20
  1. #1 My car starts up, runs, then dies. Please help
    Victoria, BC
    my 99 gtp will start up no problems but only runs for like 5 seconds then dies during the time its running it sounds fine, when it dies it does it without any coughing or sputtering sounds like its been shut off, if i keep my foot on the gas it will keep running but soon as I letup the slightest bit it dies like if im revving it at 3k and drop down to say 2.9k it dies... any ideas?
  2. #2 Re: car starts but doesn't run
    Ohio
    fuel pump resistor. in the fuse panel in the engine compartment. take out the fuel pump relay and bend pin 85 out. then reinstall the relay..should run fine then
  3. #3 Re: car starts but doesn't run
    Victoria, BC
    so tried that half worked it runs for about twice as long before she dies same thing but now while idling the rpm drops slightly almost dieing then goes back up does this 3 or 4 times then dies...
  4. #4 Re: car starts but doesn't run
    Ohio
    hmmm. unplug the maf. then start it
  5. #5 Re: car starts but doesn't run
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    had anything done to it recently?
    my car did this when i left my break booster hose off
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  6. #6 Re: car starts but doesn't run
    Victoria, BC
    have had nothing done to it recently... last thing i did was an oil change which was a month ago
  7. #7 Re: car starts but doesn't run
    Ohio
    my car still ran when the brake booster hose was off....just sounded like it had the most radical cam in it. lol
  8. #8 Re: car starts but doesn't run
    Victoria, BC
    so unplugging the MAF had no affect
  9. #9 Re: car starts but doesn't run
    Nov 2010
    Maryville, MO
    mine would rev up to 3k then fall off completely lol
    and hmm
    there was a thread like this a little while back ill see if can find it
    // 2005 Comp G
  10. #10 Re: car starts but doesn't run
    Victoria, BC
    i guess i should mention it smells like shes running rich... but im thinking that could just be the left over fuel from when she dies
  11. #11 Re: car starts but doesn't run
    Nov 2010
    Maryville, MO
    http://www.grandprixforums.net/bad-iac-tps-58637.html
    here it is had the exact same prob even with smelling rich
    // 2005 Comp G
  12. #12 Re: car starts but doesn't run
    Nov 2010
    Maryville, MO
    ^there is some things in there you could look at next
    // 2005 Comp G
  13. #13 Re: car starts but doesn't run
    Victoria, BC
    tried everything suggested there... no dice... ive unplugged bot relays 14 and 15 bent out the pins each time i did that (did them one at a time) it ran a little longer the first time before dieing then went back to dieing right away i dont see any vacuum lines unplugged i cant find any leaks as it just wont run for long enough to even try and hear if theres a leak i cleaned up my IAC had no affect unplugging the MAF has no affect she just dont want to run i tried looking underneath to see if anythings been pinched everything looks fine from what i can see kinda hard being on the ground and all... now the car was put into the ditch last week i should have mentioned that earlier i guess but it ran fine until i went to start it today im at a complete loss...
  14. #14 Re: car starts but doesn't run
    Nov 2010
    Maryville, MO
    did you try to pedal the car with the maf unplugged for a few seconds and see if it would idle out?
    http://www.grandprixforums.net/solve...dal-52641.html
    this one had the same prob didnt run with the maf unplugged, but cleaning it helped
    and as far as the ditch goes i wouldnt know i guess it depends on the extent of the damage
    // 2005 Comp G
  15. #15 Re: car starts but doesn't run
    Victoria, BC
    tried and nothing as far as damage goes i can't see any damage but it is hard to tell exactly as i have no way of getting under the car
  16. #16 Re: car starts but doesn't run
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    is ur security light blinking when the car dies?
  17. #17 Re: My car starts up, runs, then dies. Please help
    Victoria, BC
    no its not
  18. #18 Re: My car starts up, runs, then dies. Please help
    SE Level Member 1999GrandPrix's Avatar
    Oct 2011
    South Carolina
    hey onos, hey does ur car have problems at cold start in the mornings? is it just actin up when engine is warm? had the same prob. turned out to be a maf sensor.
    1999 GT
  19. #19 Re: My car starts up, runs, then dies. Please help
    Oct 2011
    South Carolina
    if ur maf had no effect when unplugging, it would make sense because ur maf is prolly dead to the point where the car is already in "safe mode" as if it was unplugged anyway. just try disconnecting maf and remove battery cables for like 15 min to clear all codes if any. then leave maf unplugged and connect battery and try to start let us know...
    1999 GT
  20. #20 Re: My car starts up, runs, then dies. Please help
    Victoria, BC
    i dont have any issues with it starting and theres no codes showing up, it just doesnt run, it was cold this morning and it started fine when i tried and just like when its warmer out runs for about 3-5 seconds then dies, i dont know how it will act with the engine warmed up as it i cant get it warmed up being that it only runs for 5 seconds at a time
  1. my car runs when its cold then dies
    By dstrow73 in forum General Tech Discussion
    Last Post: 09-15-2010, 12:42 PM
  2. Car starts runs for 3 sec and dies
    By rtwilliamson in forum General Tech Discussion
    Last Post: 06-21-2010, 01:37 AM
  3. Need some help folks, car starts, runs, then dies
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2010, 05:48 AM
  4. HELP: Starts then dies after LIM
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 06-23-2009, 03:35 PM
  5. car starts, runs for a second, then dies
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2009, 11:34 AM
