Thread: Flushing coolant, tips?
Results 1 to 19 of 19
  1. #1 Flushing coolant, tips?
    Jul 2010
    Philly
    Im chasing some bugs in my car. I think a coolant flush could help sort some things. I have a question though, my plan to flush is to removal the T-Stat and run 100% water for a few days with some of that flush cleaner. Plan to do it as many times till I get clean water out the rad. Then with a new T-stat put in some fresh 50% 50% and be done. Sound like a good plan? Also how do I bleed the system? And one last question, I see all the anti freeze on the shelfs say can be mixed with anything. I cant seem to find plan green anti freeze anymore (dex cool car from the factory). What should I look for in the stores?
  2. #2 Re: Flushing coolant, tips?
    i would not remove take the thermostat out and run the car for a few days, sounds like a good way to make things worse.
    Just pull the lower rad hose, to drain the coolant. Fill it back up through the LIM with water, put thermo back in
    , then run the car till it opens to cycle the water for like 5-10min, then keep doing that untill the water is clear.
    Then on the last one, fill the rad and LIM with coolant, any kind, green or yellow, dont matter. put new thermostat in, then run the car up to temp, with the the bleed screw ontop of the thermo housing open about 1-2 turns, wait for all the air bubbbles to come out and just solid coolant stream, it might take a while to completely get the air out.
  3. #3 Re: Flushing coolant, tips?
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    Little advice.
    For 2 bucks more u get just a full gallon of antifreeze. Take an empty milk gallon and fill that half way. Pour half the gallon of antifreeze in then the half of galon of water. With the half thing of antifreeze mix it with water and fill that up. Now u have 2 gallons of 50/50 for 10 bucks.
    But yeah there's really no point to run ur car with water for a few days. Flush the dexcool out and put the good ol green stuff in there.
    The Boss Iceman6669's Avatar
    Jun 2011
    I just did mine.... I did something like what you wanna do. I drained all the coolant, removed Tstat, and refilled with water. Ran that for about 20 mins or so. Drained and repeated two more times. Then filled just like ^^^ they said too.
    2011 F-150 Yote powered
  5. #5 Re: Flushing coolant, tips?
    Nov 2011
    NY
    Just a heads up! But you want to use DISTILLED water when adding/mixing the anti-freeze!
  6. #6 Re: Flushing coolant, tips?
    Nov 2010
    Illinois
    says who? never had any problem with good ol tap water. done it on ton of vehicles for years
  7. #7 Re: Flushing coolant, tips?
    GT Level Member tmackster's Avatar
    San Antonio, TX
    question about bleeding air out of system. everytime i loosen bleeder valve...i never hear air coming our....can u just unscrew the bleeder valve all the way and then put it on....b/c i thing my bleeder valve may be clogged. idk
    '06 GP GT // Debadged // 20" Niche Venice rims w/toyo proxes4 tires, ram air inferno hood, front air dam, SE rear valance, black l.e.d. tail lights, CAI, MSD Ignition wires, Pioneer 6x9, & 10,000K HID headlights!!!
  8. #8 Re: Flushing coolant, tips?
    Quote Originally Posted by tmackster View Post
    You wont hear it. When the car is running and as the coolant passes it and goes back through the thermostat into the block, small amounts of air escape out the hole, once most of the air is gone, coolant will start to bubble out, then solid stream with mainly all the air it out.
  9. #9 Re: Flushing coolant, tips?
    GTP Level Member
    Nov 2011
    Kansas
    I jsut flushed mine with the green and the car is running liek 10-15 degrees hotter.... is there a correlation from dex to the green stuff?? Also, that 10 degrees pushes my needle a little over the half way mark on the guage.
  10. #10 Re: Flushing coolant, tips?
    Nov 2010
    Illinois
    Develand,
    Anti-freeze is exactly what it is. It doesn't freeze and it doesn't evaporate so its basically water that anti freezes and doesn't evaporate.
    So, the difference between green and dex is that if ur next door neighbor's dog licks the dex it won't die. And dex smells real rotten when its old.
    U shouldn't see a temp difference unless u too didn't bleed the air.
  11. #11 Re: Flushing coolant, tips?
    Nov 2011
    NY
    Quote Originally Posted by bps02gtp View Post
    First - a few assumptions. One is that most people are not on treated water systems. Therefore the water contains contaminants, i.e., minerals, salts and more. Soooo... even though you might have done a ton of vehicles and noticed no problem. Have you also been with those vehicles over their lifespan?
    Anti-freeze is not made when manufactured with TAP water, so why would we assume It's ok otherwise. The minerals, salts and other impurities are akin to taking some dirt and throwing it in the coolant as well. Distilled water contains none. So It's simple. If your not in a pinch, like overheated and need to fill coolant and are going to mix your own anti-freeze, in MY opinion, distilled water is the better choice.
    It's a suggestion and by WHO is "me"... Unless for some reason that part was missed in MY original post. The great thing about these forums is that any user can gather a multitude of opinions and make their own decision, thank you very much. But there really is no need for anyone to come off as the End-All answer man by statements such as you've made... i.e., says who???
    Anyway... Have a great day!
  12. #12 Re: Flushing coolant, tips?
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    what's wrong with the NY tap water??
  13. #13 Re: Flushing coolant, tips?
    Jul 2010
    Philly
    I have lots of that Dexcool mud, water will be enough to get it out?
  14. #14 Re: Flushing coolant, tips?
    yes, if you do it a few times.
  15. #15 Re: Flushing coolant, tips?
    Nov 2010
    Illinois
    i never attempted to come off as the "end all answer man". i was just wondering says who because i actually want to know who says its so better? GM? Ford? you? other forum ppl? when you do something like This then to me that means its very important and that you cant do it any other way. but you can. so instead of making such an end all statement with such a big font size you should say IMO distilled water is way better than tap and not make it seem like its the end of the world if you do something different. and yes actually i have been with 3 of the many many MANY cars i have done it to and they are all fine. i gurantee that if anything happens to them to where it doesnt run it wont be because of tap water. has anyone had a car go through its life span where tap water hurts?
    and when you say most people dont have treated water i assume that u mean they're using well water. all tho i could be wrong i kinda think majority uses city water instead of well. i wouldnt brush my teeth with well water so i kinda hope ppl wouldnt put that dirty crap in their radiator but idk.
    so yeah with ppl being able to make their own decision on here based off of peoples opinions it should be because they were informed that there is a right way and a wrong way not a must do because in someones opinion it is better way.
  16. #16 Re: Flushing coolant, tips?
    Nov 2011
    NY
    i never attempted to come off as the "end all answer man". i was just wondering says who because i actually want to know who says its so better? GM? Ford? you? other forum ppl? when you do something like This then to me that means its very important and that you cant do it any other way. but you can. so instead of making such an end all statement with such a big font size you should say IMO distilled water is way better than tap and not make it seem like its the end of the world if you do something different. and yes actually i have been with 3 of the many many MANY cars i have done it to and they are all fine. i gurantee that if anything happens to them to where it doesnt run it wont be because of tap water. has anyone had a car go through its life span where tap water hurts? and when you say most people dont have treated water i assume that u mean they're using well water. all tho i could be wrong i kinda think majority uses city water instead of well. i wouldnt brush my teeth with well water so i kinda hope ppl wouldnt put that dirty crap in their radiator but idk. so yeah with ppl being able to make their own decision on here based off of peoples opinions it should be because they were informed that there is a right way and a wrong way not a must do because in someones opinion it is better way.
    No problem... Here's one of the best explanations I could find on the net. I based my statement on something similar I read a very long time ago and can't remember where I did, so this is the next best thing.
    Learning Coolant Fundamentals
    Again, NYC Tap water is probably the best to drink, lol, but most of us have hard water in various forms. Home water while probably not so bad, if it (your water) is high in the hardness scale and you SOFTEN the water for home use, well then, I would suggest using Distilled water. Especially since most garden hoses are connected prior to the softening system/equipment.
    My apologies as well, I wrote that response early in the a.m. and was not a good day, yes even that early. I think It came out worse than I intended.
    Regards!
    Loooooooool you don't tear down your rad to inspect for build up so my hat is a bird.
  18. #18 Re: Flushing coolant, tips?
    Jul 2010
    Philly
    For what its worth I always you distilled as well.
  19. #19 Re: Flushing coolant, tips?
    new britain, ct
    i mean, distilled water just makes sense.
    07 Black GXP.
  1. Dual tips or trapezoid tips?
    By GTLGDP in forum Visual/Body Modifications
    Last Post: 01-19-2012, 11:42 PM
  2. Can flushing your lines cause a heater core to blow?
    By Sazy in forum General Tech Discussion
    Last Post: 01-25-2011, 08:28 PM
  3. flushing DNS
    By aubry118 in forum Forum Bugs/Suggestions
    Last Post: 11-10-2010, 07:11 PM
  4. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  5. looking for tips
    By dkski123 in forum Shops and Community Heroes
    Last Post: 05-03-2010, 08:57 AM
