Thread: Window Problems
Results 1 to 3 of 3
  1. #1 Window Problems
    SE Level Member Lawenforcer's Avatar
    Shelbyville, IL
    Today, I was heading to work and rolled my drivers side window down. It went down just fine but didn't want to roll back up. I think the motor is fine cause after pushing the button up SEVERAL times it finally went up. So it will roll down just fine just not up. I am thinking maybe a bad switch in the controls, all other windows go up and down just fine on those same controls. Any suggestions before I go buy parts that I don't need. Thanks again for all the help...
    2000 Grand Prix GTP
  2. #2 Re: Window Problems
    St. Louis
    Try lubing the window guides w/ something like WD-40 (everyone has this) and run the window up and down a bit and see if it frees up. Could be a switch but a lot of times it a sign that the guides are dry and the glass is sticking to it.
  3. #3 Re: Window Problems
    Shelbyville, IL
    Problem solved....It was indeed a bad switch...I just bought a used master switch of ebay and fixed the problem....
    2000 Grand Prix GTP
  1. Window problems
    By Robby Avery in forum General Tech Discussion
    Last Post: 01-18-2011, 07:04 PM
  2. Help Window Problems
    By JoshsGTP in forum General Tech Discussion
    Last Post: 08-24-2010, 10:59 AM
  3. plz help me with my window problems
    By cavalier6908 in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2010, 08:10 PM
  4. Window Problems
    By KawaFord in forum General Tech Discussion
    Last Post: 09-24-2009, 06:26 PM
  5. Window Problems
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2008, 05:02 PM
