Thread: Help Window Problems
Results 1 to 4 of 4
  1. #1 Help Window Problems
    Akron Ohio
    OK 1997 GTP 2dr, my drivers and passenger windows seem to get caught up at the front of the window, then the back of the window goes out of the rubber seal. Ive been trying to fix it but I cant figure out what it is. I was wondering if anyone had this problem and had it fixed?
  2. #2 Re: Help Window Problems
    Jul 2010
    Outside ATL
    have you pulled the panel off to see what is going on inside that door panel. Cable twisted, broken guide wire, there is a lot of plastic that can break on those regulators. If your window is out of track you will see it clearly and you will also notice any other odd behavior if you just take a peak.
  3. #3 Re: Help Window Problems
    Akron Ohio
    Ive looked at it all I cant figure out what it is I might just buy a new regulator
  4. #4 Re: Help Window Problems
    Jul 2010
    Outside ATL
    might be your best bet, if they havent been replaced they will go out eventually anyways.
  1. window problems
    By NomeCrusher in forum General Tech Discussion
    Last Post: 06-24-2010, 02:42 PM
  2. plz help me with my window problems
    By cavalier6908 in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2010, 08:10 PM
  3. Window Problems
    By KawaFord in forum General Tech Discussion
    Last Post: 09-24-2009, 06:26 PM
  4. window problems
    By dvaughn in forum General Tech Discussion
    Last Post: 07-31-2009, 05:06 PM
  5. Window Problems
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2008, 05:02 PM
