Thread: Won't start steering wheel hard.
Results 1 to 10 of 10
  1. #1 Won't start steering wheel hard.
    SE Level Member fakir's Avatar
    Mar 2012
    Edinburg, TX
    My wife borrowed my car and while driving back the car died and the steering wheel got hard and turned off.
    The car does try to start-up, I've checked the fuel pump and it's good. I believe is the crank sensor.
    Can someone help please.
  2. #2 Re: Won't start steering wheel hard.
    could be crank sensor.
    hard to say with the little info I know.
  3. #3 Re: Won't start steering wheel hard.
    Minnesota
    Yeah it's probably the crank sensor because you lost total power. Did you check the alternator?
  4. #4 Re: Won't start steering wheel hard.
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    What makes you believe it's the crank sensor? If the car stalls out of course it's going to be hard to steer, you don't have any power steering.
    For all your 3800 needs:
  5. #5 Re: Won't start steering wheel hard.
    Mar 2012
    Edinburg, TX
    check the alternator is good and the battery is brand new,
  6. #6 Re: Won't start steering wheel hard.
    St. Louis
    Check all the fuses? Underhood and in the car. Could just be that simple.
    Then move on to verifying if you have spark and fuel. You checked the fuel pump? How? Does it whine for a few seconds when you turn the key on? Also, give us a year and model of this GP.
  7. #7 Re: Won't start steering wheel hard.
    Mar 2012
    Edinburg, TX
    '04 GT2...
    I heard the whining for the fuel pump, disconnected each spark plug and it throws fire on all of them.
  8. #8 Re: Won't start steering wheel hard.
    Mar 2012
    Edinburg, TX
    here's a dumb question... I know what the problem is, but where is it located at? jeje
  9. #9 Re: Won't start steering wheel hard.
    Where's what located at?
  10. #10 Re: Won't start steering wheel hard.
    St. Louis
    He's referring to the CKPS. It's in another thread in the N/A forum.
  1. Hard to start GTP
    By jcnavalacademy in forum General Tech Discussion
    Last Post: 09-12-2013, 09:00 AM
  2. hard steering
    By learnAsUGo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2011, 10:04 AM
  3. Car hard to start.
    By gtp99jlp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2010, 11:44 AM
  4. Hard Power Steering at IDLE
    By Blownbyyou in forum General Tech Discussion
    Last Post: 03-12-2010, 09:59 PM
  5. HARD steering low RPMS
    By drunknmunky in forum Brakes/Suspension/Chassis
    Last Post: 10-06-2009, 07:17 AM
