Thread: SE/GT Compatibility
Results 1 to 14 of 14
  1. #1 SE/GT Compatibility
    GT Level Member ShadowSwept's Avatar
    Kentucky
    Is there any functional difference between the motor mounts in the SE and GT? I noticed the front mounts on the SE hook over the front of the frame, while the GT is simply bolted to the top and almost looks incomplete. I kind of like the look of the SE mounts better and was considering swapping. Any thoughts?
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
    SE Level Member Myprixxx's Avatar
    Apr 2008
    Decatur, IL
    I think some years were different not the trim level. I have a buddy with that same style wrap around mount on his 97 gtp. I would guess the would be swappable though you may have to fine tune the holes in the support a bit
    i knew this guy wasn't b/sing.
    michigan people have better stuff to do, like finding jobs or avoiding robbery.
    quoted from noreasonwhyy
    GenV, Full sized I/C, HAI, 3.0 MPS, N* TB
  3. #3 Re: SE/GT Compatibility
    Do you have pics of what your talking about? I'm not sure what you mean.
  4. #4 Re: SE/GT Compatibility
    got pics of what you are talking about. Because im unsure of the difference, unless you have a 3.1
  5. #5 Re: SE/GT Compatibility
    i know what your talking and i got pics ill post in a min
    SMGPFC Member #10
  6. #6 Re: SE/GT Compatibility
    gt ones
    Mine se
    Notice how the dog bone mounts hangover on the SE's
    thats what the OP's talking right?
    SMGPFC Member #10
  7. #7 Re: SE/GT Compatibility
    Kentucky
    Yep, that's exactly what I'm talking about.My old car was an SE that gave out on me, now I have a GT- both are 2003. The GT's previous owner and the dealer I bought it from 'lost' a few parts so I've been picking scraps. I thought the mounts on the SE looked better but wanted to be sure there wasn't a reason for the difference before I swapped them. Plus I just flipped the mounts on my GT
    2003 Grand Prix GT
  8. #8 Re: SE/GT Compatibility
    It probably wont make any difference
  9. #9 Re: SE/GT Compatibility
    Kentucky
    Anyone know if the radiator and fans are interchangeable between the SE 3100 and the GT 3800?
    2003 Grand Prix GT
  10. #10 Re: SE/GT Compatibility
    Should be the same the gtp iirc had a little bit thicker radiator.
  11. #11 Re: SE/GT Compatibility
    should be the same, if anything the gt one may be just a little bit thicker. But i think there the same
    SMGPFC Member #10
  12. #12 Re: SE/GT Compatibility
    Kentucky
    I'm more concerned with the fans at the moment, as the ones in my GT look funky and asymmetrical, while the SE fans are in good condition. However, I did notice some dents in the front of my GT's radiator fins, if it's too bad I might swap with the SE - that one is brand new.
    2003 Grand Prix GT
  13. #13 Re: SE/GT Compatibility
    I haven't messed with a 3100 gp in a while but you should just be able to use the fans off the 3800. The rad should be the same. How can you see the rad? The condenser is in front of the radiator.
  14. #14 Re: SE/GT Compatibility
    Kentucky
    Looking underneath. Barely a glimpse so I'm hoping it's just a bad spot.
    Condenser doesn't look so great though.
    2003 Grand Prix GT
  1. Parts Compatibility
    By w98seeng in forum General Tech Discussion
    Last Post: 02-12-2012, 06:07 PM
  2. MAF compatibility
    By benner in forum General Tech Discussion
    Last Post: 06-13-2010, 05:34 PM
  3. DP and Powerlog Compatibility
    By Bedwards in forum Turbo
    Last Post: 11-22-2009, 05:21 PM
  4. Compatibility
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-19-2009, 02:34 PM
  5. 2DR / 4DR seat compatibility
    By StreetChariot in forum General Tech Discussion
    Last Post: 03-28-2009, 11:45 AM
