Thread: Where did this bolt come from???
Results 1 to 16 of 16
  1. #1 Where did this bolt come from???
    Mar 2012
    maryland
    Well when i did the head gaskets on my wife's car i happen to be tinkering with it and discovered i left out a rather large bolt(sitting on the wiper arm where i left it).I'm pretty sure it came from the right side of the engine around the tensioner ,water pump ,alternator area.I'm thinking maybe it's in a hidden spot and sandwiched between the engine and coolant overflow or such an area where i can't readily see.I have all three tensioner bolts in ,alternator bolts are in as well as the engine supports kinda scratch'n my head now.I figured one of you guru's could put a finger on it.It's has a 15mm head and it's about 5 inches long.Let me try to post a pic. [IMG][/IMG]
    [IMG][/IMG]
    Thanks
  2. #2 Re: Where did this bolt come from???
    it could be an alternator bolt. or from the tensioner assembly somewhere.
    get in there and look around.
  3. #3 Re: Where did this bolt come from???
    Kansas
    What Bio said.
    There is 3 bolts holding on the tensioner assembly. And three holding on the alternator.
  4. #4 Re: Where did this bolt come from???
    that does look like the long bolt for the alternator. i seem to recall mine having no threads at the end of it too.
  5. #5 Re: Where did this bolt come from???
    Kansas
    I just had mine out last night. I'm pretty sure it is the alternator, since the tip is rounded. The ones from the tensioner assembly had no threads at the end, but flat.
  6. #6 Re: Where did this bolt come from???
  7. #7 Re: Where did this bolt come from???
    Rounded tip is an alternator bolt.
    Make sure you didn't drive a bolt through the valve cover.
    Seen that before.
  8. #8 Re: Where did this bolt come from???
    Likely the bolt that would be on top in this pic.. you can't see it with the mount on.
  9. #9 Re: Where did this bolt come from???
    Mar 2012
    maryland
    LOL.What a great idea.Already did.I'm not asking for help because i'm too lazy to look.Just can't put my finger on it.
  10. #10 Re: Where did this bolt come from???
    Mar 2012
    maryland
    Seen that before.
    It's a possibility that i could have swapped it with another bolt by accident.All three tensioner bolts are in there.All the Alternator bolts are in too.Because the one has the support bracket hooked to the top.Yeah i almost ran the bolt through the valve cover.But luckily i was watching.
  11. #11 Re: Where did this bolt come from???
    Seen that before.
    My buddies car had that happen to it. Noticed it when I did the LIM on it. The fix? black rtv over the hole lol
  12. #12 Re: Where did this bolt come from???
    Portland Oregon
    That also looks like a dogbone bolt.
  13. #13 Re: Where did this bolt come from???
  14. #14 Re: Where did this bolt come from???
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    I did the exact same thing when I did my lim job!!! Don't freak out ull be ok without it but if u can get to it easily throw it on.
  15. #15 Re: Where did this bolt come from???
    Mar 2012
    maryland
    Quote Originally Posted by bps02gtp View Post
    Yeah,really wasn't sweating it too much.Engine didn't fall out.lol
  16. #16 Re: Where did this bolt come from???
    Quote Originally Posted by upsman72 View Post
    Snicker snicker...Dave...ever hear of that happening?
  1. WTB: Bolt in TOG dp.
    By glanzergtx in forum Wanted To Buy - Parts
    Last Post: 02-28-2012, 09:55 PM
  2. Bolt on parts for LS4
    By buckslayer in forum 5.3L V8 (LS4)
    Last Post: 03-19-2011, 12:55 AM
  3. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  4. will this bolt right in?
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 08-06-2010, 07:26 PM
  5. Bolt Ons?
    By TMOTA503 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-03-2008, 10:06 PM
