Thread: Intake Fan?
Results 1 to 7 of 7
  1. #1 Intake Fan?
    GT Level Member ShadowSwept's Avatar
    Kentucky
    When using a HAI, would there be any advantage to installing a fan either behind the headlight or in the fender area, wired either into the radiator fans or just on when running? Thought it might help bring in some air, especially with city driving. Any thoughts?
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
  2. #2 Re: Intake Fan?
    St. Louis
    If you want to keep things cooler then I would get a different thermostat and a tune to have the fans come on sooner. Or a more efficient radiator. Keeping the air warm instead of hot really won't make that much of a difference. Now a cowl hood and fan may work to keep the underhood temps down, but seeing as how these motors run hot by design it's really not worth the effort IMHO.
  3. #3 Re: Intake Fan?
    air moves through that area by itself. a fan would be a restriction.
  4. #4 Re: Intake Fan?
    Kentucky
    I was thinking a large diameter, low-profile fan might help increase airflow at low speeds without being too much of a restriction. Surely the amount of air pulled in would more than make up for the space of the fan?
    Quote Originally Posted by FordMan77 View Post
    Other than what I'm guessing was a fluke just after installing the HAI, the temp stays at 185 max. I just thought a fan in the fender area might serve to add some of the benefits of a CAI without the full setup, as it would blow directly on my air filter. Just a thought.
    2003 Grand Prix GT
  5. #5 Re: Intake Fan?
    Feb 2009
    flintnasty MI
    hot air performs a bit better at cruise than cold air does.
  6. #6 Re: Intake Fan?
    GTX Level Member blackflag's Avatar
    Virginia
    At Idle and low speeds maybe. Once you hit 35-40mph temps in that area are ambient by design. After you reach those speeds the fan is just in the way. I dont think it would disrupt air flow completely, since thats not the only area that pulls fresh air.
    Also a high powered fan might cause alternator strain. Not worth it IMO, Save the $50 it costs to build and save for an intercooler.
  7. #7 Re: Intake Fan?
    Kentucky
    Quote Originally Posted by BlackFlag View Post
    Alright. Thanks anyway!
    2003 Grand Prix GT
  1. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  2. Short Ram Air intake or Cold Air Intake
    By slopez in forum General Tech Discussion
    Last Post: 02-01-2011, 10:08 PM
  3. Intake help!
    By Amb4 in forum General Tech Discussion
    Last Post: 12-03-2009, 07:56 AM
  4. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
