Quote Originally Posted by stlmo_gtp View Post
yea mine goes off and then the first time i goto brake when driving it the brakes feel all weird it feels like they try to lock up and then the abs light kicks right back on, idk what it would be tho, changed the brakes all the way around, and bleed then so.. i am a little in the dark myself
Sounds like both of you are having issues with a bad wheel speed sensor. The codes are still stored, even though the light is off. It keeps a history for something like 60 key cycles. So get it scanned and get it taken care of.
The problem with just letting it go is that it will make your ABS act all weird. Sure doesn't seem like too much of a problem. But you never know what it is going to do under hard braking if you are having issues. Could lock one wheel up, and not the other, and send you into a spin. Not good when you just need to stop.
