Needing some input on what many people I talk to are calling a strange problem.
A few months back I was driving my turbo gp down the interstate and go to pass someone. While i was in boost i had a the #3 sparkplug close(no gap) I get the car home and discover the problem but really don't know what to think about it. I replace the spark plug and everything sound and runs great... until. A couple weeks ago i went to visit my parents and once again on the highway and passing someone my SES light starts flashing again and the engine was running rough like it had the previous time. So sure enough i pull the plugs to find that #5 had closed just like #3 had before. I baby it home after getting the plug fixed and decide to change plugs. I got them changed only this time i can hear a slight ticking noise that increases with rpm. After everything i've read and from what car people have told me is that there is nothing else that could have closed the gap on the plugs except for a chipped piston. So i really don't have the $ right now to change pistons or really for gaskets to pull the heads and look. But i got to thinking that if I had chipped the piston that surely it would have done damage to the turbine wheel of the turbo. So i pull the turbo off and look at the exhaust side and it looks as straight and true as the day i got it. Had even a small piece of the piston gone through it those small fins would have had some damage.
Now for your input!
After taking the plugs back out of those trouble pistons they seem to have more of what i'll say to be oil on them than the rest.
What should i be looking for? possible bad valve seats? bent pushrod?
FYI both times it happed was under boost(under 10 psi.)
AFR was right where it should have been for PE
Timing seems to be at a good point with no KR registering on my scanner
And i am intercooled....
Solve the puzzle and Scott will buy you a lolly pop!
Thanks guys
