Thread: water-pump's possibly going out?
Results 1 to 20 of 25
  1. #1 water-pump's possibly going out?
    I recently have new green coolant instead of the dex-crap and using a drilled 180* t-stat. on the freeway if I do a few minimal spirited driving, not100% throttle but upwards to 75%, my ect would spike as much as 204*F along with the trans fluid(I run a gm auxiliary trans-cooler after the radiator) on a 90+ degree day. Is that normal or is my water-pump not keeping up the cooling process? I do have my fans on at high speed(speed 2) as well. the water-pump’s OEM and the cars at ~149K miles. FWIW on a normal driving around, the ect is around 185-187*F in 85+ degree temps
    What’s the correct part number for the water-pump on rock auto? Their site has ACDELCO Part # 252693 for both 2 and 4 door. Also I did a search on here and found no write-up available for installing a water-pump. Anyone care to give me a (semi)-detailed instructions on the amount of work im looking at? Thanks in advance!!
  2. #2 Re: water-pump's possibly going out?
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    I'm not sure what Rock auto is charging but I have a 33K mile OEM WO with new gasket for $30 shipped.
    Install is pretty easy really:
    loosen 4 bolts on WP pulley
    remove accessory belt
    remove WP pulley
    remove 2 power steering pump bolts - 1 at 12 and the other at 6:00 positions, they are 13mm
    remove WP bolts - 13 and 10mm
    scrape ALL old gasket material off - check again - re check -and check again you got it all
    I apply a very thin layer ot RTV to the engine side of the gasket and the water pump
    Install all bolts using thread sealer. Permatex makes a good high temp seal in a small white tube
    Finish installing everything else in reverse
    Remove T-stat housing and T-stat
    Fill LIM with coolant/water mix
    Reinstall T-stat and housing
    Start car and let run until warm
    Let sit for 1 hour
    remove radiator cap and top off with coolant/water mix
    drive car until warm and repeat until radiator stays full
  3. #3 Re: water-pump's possibly going out?
    good to know, thanks vinnie, i should drain the coolant b4 taking off parts for the waterpump right
  4. #4 Re: water-pump's possibly going out?
    Saraland Alabama
    yes drain it a new one is about $30 locally at advance
  5. #5 Re: water-pump's possibly going out?
    lol ok, thanks...does it sound like it needs replaced soon though? i know its a good idea to do so especially on the mileage its running on.
  6. #6 Re: water-pump's possibly going out?
    Saraland Alabama
    mine went suddenly and ate the belt (locked up solid)
  7. #7 Re: water-pump's possibly going out?
    Las Cruces, NM
    It will drain wen you remove it Just put a pan down there.
  8. #8 Re: water-pump's possibly going out?
    yea i know it'll drain when i remove :-P....just wondering if doing it that way would be better/cleaner or if i should drain via the drain cock down by the radiator or both?
  9. #9 Re: water-pump's possibly going out?
    Bastard Reptile's Avatar
    Kansas City, MO
    the water pumps will usually leak out of the weep hole when they start to go bad. It almost sounds like it may be a coolant hose/radiator issue. If the dex wasn't flushed out correctly when you put the green in, this may be your problem.
  10. #10 Re: water-pump's possibly going out?
    hmm ic....i tried to clean the dex-cool out as much as i could. the coolant overflow tank, thats another story as i tried to clean it spotless but couldnt get into the corners with a garden hose. also my OEM radiator fins do have small dents since it is 148K. possibly time to upgrade or replace the radiator instead or just do both? lol....
  11. #11 Re: water-pump's possibly going out?
    Kansas City, MO
    I think it's prestone that uses a radiator flush that's a little acidic, and it seems to work good on cleaning the sludge out. I wish I could remember the name of it.
  12. #12 Re: water-pump's possibly going out?
    any torque specs on tightening the WP?
  13. #13 Re: water-pump's possibly going out?
    Las Cruces, NM
    I can't say off hand but I would guess the smaller bolts are only 10-12lbs and the larger are 15-18lbs. Not too tight.
  14. #14 Re: water-pump's possibly going out?
    Las Cruces, NM
    I found this in the how-to section:
    Water Pump Bolt
    15 N·m + 80°
    11 lb ft + 80°
    Water Pump Pulley Bolt
    13 N·m
    116 lb in
    I was pretty close
  15. #15 Re: water-pump's possibly going out?
    will i just hand tightened them to the point it felt like not going further. when i broke the bolts loose b4 it was really easy to break the 13mm bolts, but the 10mm needed a tad bit more force. i applied teflon paste on all the bolts, even teh 10mm as well, even though i noticed the 13mm were the only ones covered in white crusty old teflon paste.
  16. #16 Re: water-pump's possibly going out?
    Las Cruces, NM
    Smart move! Good job.
  17. #17 Re: water-pump's possibly going out?
    i ran ot of day light so i'll aim to finish the install tomorrow after i get off work. just need to reinstall the power steering pump, WP pulley, s/c oversized pulley, belts then as directed, pull the t-stat housing and t-stat and pour coolant in and tighten the t-stat housing up(hopefully the gasket and o-ring wont bust on me) and start the car up til warm and then turn off and let sit, etc etc.
    also i looked over the old WP and it spun fine....now i dont know if the overheating is from the old WP, perhaps the radiator is the problem? i noticed someof the fins on it are a bit bent and such. i've been using the prestoen green stuff, so i dont know what else 'could' be the problem if the new WP doesnt do the trick. another possibility is a bad t-stat? im using a drilled 180* t-stat FWIW.
  18. #18 Re: water-pump's possibly going out?
    Las Cruces, NM
    Did you mix that green with what was already in there? You probably made sludge if you did.
  19. #19 Re: water-pump's possibly going out?
    waterpump install went successful, thanks guys and especially vinniegtp for the cliff-note step by step lol.....bled the coolant via the bleeder and swapped the t-stat from the drilled 180 to a non-drilled and temps ranged in the 177* at idle. havent driven it yet as well as doing some spirited driving yet, but will soon sometime this week(going to cecil this friday hopefully).
    edit-i tried to wash all of the dex-cool out last summer as much asi could via garden hose. i filled the radiator with water and let the car idle for a bit to let the water circulate around in the radiator and block then flushed it again then filled it with the green stuff
  20. #20 Re: water-pump's possibly going out?
    Las Cruces, NM
    You're very welcome. I'm glad it all worked out. I like being able to help.
    Ok, then you should be ok af far as mixing coolant goes.
  1. Vegas anybody? possibly reno?
    By GTPformee in forum West
    Last Post: 01-17-2010, 02:24 PM
  2. Quite Possibly the Ultimate in Car Search
    Last Post: 07-29-2008, 01:30 PM
  3. fuel pump's fauiling on me??
    By fst in forum General Tech Discussion
    Last Post: 03-21-2008, 12:10 PM
  4. Possibly Add Torque under edit details
    By JashGTP in forum Forum Bugs/Suggestions
    Last Post: 01-03-2008, 10:22 PM
