Well i waited too long to fix my o2 sensor, now my EGR is bad. I saw this on RockAuto, is this right?
STANDARD MOTOR PRODUCTS Part # EGV466TT-Series
It says is $65, which i can deal with paying. Does anyone know if it comes with a gasket?
Call rockauto. I do it all the time. They will give u a call back within 10 minutes wih an answer
You can just pull your egr off and clean it and see if it fixes your problem.
lol but those dont answer his question!
You will have to block it off on the exhaust and tune it out, but I would delete it. All it does is push carbon back into your motor and save a very little amount of gas.
Turning it off in the tune means it don't open. Means you don't need a block off. Right?
Just disconnect the connector from the thing and get a tune that deletes the code from appearing...![]()
Will somebody just answer the damn question if it has a gasket? Lol wtf
When my egr went bad it was stuck open. So I was getting too much nasty exhaust gasses at low speeds. So when I would try to accelerate slowly it would "chug" and stumble till I gave it more throttle.
An EGR can do many things. However without the code etc, we'd be guessing at what it can do. Please post more info and we can likely help further.
For $65 I'm pretty sure it's not coming with a gasket.
