Thread: Kinda OT... Need another Tech input. 05 F150 Brake lights/Turn Signals/Hazards Failed
Results 1 to 2 of 2
  1. #1 Kinda OT... Need another Tech input. 05 F150 Brake lights/Turn Signals/Hazards Failed
    GT Level Member Brian99SE's Avatar
    Dec 2011
    Cadiz, Ky
    At work we have a 2005 F150, 5 Speed,6 Cylinder.
    My boss was picking up parts about 6 hours away from home and the Turn signals stopped working on the truck.
    All together the Brake, Turn Signals, and Hazards just failed.
    Fuses checked good. I remember the older F150's had an issue of the wires getting "pulled" in the steering column, Causing the circuit to be open to the Hazard switch which caused all the lights to fail.
    Unsure if the newer trucks are having that same issue, Multiple google searches yeild me nothing but relations to the older models.
    Thanks!
    99 Grand Prix SE-Blue CAI, 3.03 GR Transmission, U Bend Delete.
    time to call the exterminator
  2. #2 Re: Kinda OT... Need another Tech input. 05 F150 Brake lights/Turn Signals/Hazards Fa
    St. Louis
    Check out these threads. Could be related to the MFS, or even the tilt column. And yes, the column was still an issue on that years
    Turn signals and hazard lights not working - F150online Forums
    '06 F150 Turn signal problem. - F150online Forums
  1. High beams turn on intermittently when using turn signals
    By Boomersooner in forum General Tech Discussion
    Last Post: 01-13-2012, 08:31 PM
  2. turn signals and brake lights
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-14-2011, 06:02 PM
  3. car wont turn over after failed header install
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2010, 02:24 PM
  4. brake lights, cigarette lighter, turn signal wont work
    By dlouis30 in forum General Tech Discussion
    Last Post: 03-03-2010, 10:31 AM
  5. turn signals
    By echarleswhyte in forum The Rant Forum
    Last Post: 12-07-2009, 09:49 PM
