Thread: How do i remove driverside mirror control knob from bezel
Results 1 to 7 of 7
  1. #1 How do i remove driverside mirror control knob from bezel
    Phila
    I know how to remove the bezel from door but I can't figure out how to remove the power mirror control from the bezel. I'm assuming I can pop the other two modules out with a screwdriver?
    Thanx in advance for any info.
  2. #2 Re: How do i remove driverside mirror control knob from bezel
    London Ont, Canada
    exactly, just do it carefully because the plastic tabs will break.
  3. #3 Re: How do i remove driverside mirror control knob from bezel
    Phila
    That still doesn't tell me how to remove the mirror control knob
  4. #4 Re: How do i remove driverside mirror control knob from bezel
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Pop out the door panel and just look how its secured. I have a Regal so I dont know but I know all mine came out just fine just had to stare slowly at the for a minute. lol
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  5. #5 Re: How do i remove driverside mirror control knob from bezel
    St. Louis
    I think it's a small allen screw that hold it in there.
  6. #6 Re: How do i remove driverside mirror control knob from bezel
    London Ont, Canada
    its two plastic clips, gently pry them up and push the knob out.. its really not something that can be explained properly. you really just need to get in there and do it.
  7. #7 Re: How do i remove driverside mirror control knob from bezel
    Phila
    I was able to do it but not really sure whaqt the proper way is. There are 3 small clips which I was aware of and I broke one. I stuck a screw driver in there and just kinda popped it out. I didn't think the clips had much to do with it because the new bezel had the clips on it. The good thing is I was replacing it so I didn't care if it broke. Thanx for all the responses.
  1. Climate Control Knob
    By cutiger80 in forum General Tech Discussion
    Last Post: 04-03-2010, 06:39 PM
  2. Climate Control Knob???
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 10-30-2009, 01:15 PM
  3. Subwoofer Control Knob
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 05-04-2009, 07:48 PM
