Thread: Heater not working
Results 1 to 13 of 13
  1. #1 Re: Heater not working
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    there is no such thing as a sending unit unless they are refering to a water pump. that or your coolant elbows could be leaking but it is unlikely with low mileage. who knows double check
    there is whats called a reverse flush on your heater core. sometimes they get a little clogged. theres 2 hoses. take them both off and use a hose to push water through both ways gently until you get an even flow in both directions. you should notice that the flow starts off a little slow and then gets fast. if it does then it was slightly clogged. and yes at a 100k miles you want to put some fresh anti freeze in there so just do a complete flush and you should be good to go.
    if that doesnt work then you have an issue with your "blend actuator" i think is what its called where you control the temperature of your air coming through from hot to cold.
  2. #2 Re: Heater not working
    May 2011
    Temecula
    There is actually a sending unit, in fact Im pretty sure there are 2 of them.
  1. Heater Not Working
    By teamfbody in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-01-2011, 11:05 PM
  2. Heater stopped working
    By ls1camino in forum General Tech Discussion
    Last Post: 11-08-2011, 02:36 PM
  3. Heater control - intermittantly working
    By Skrappi69 in forum General Tech Discussion
    Last Post: 10-04-2011, 09:11 PM
  4. Heater not working properly
    By dms13 in forum General Tech Discussion
    Last Post: 12-13-2010, 07:16 AM
  5. Troubleshooting Help? DIC & heater/AC not working
    By TMC in forum General Tech Discussion
    Last Post: 12-12-2010, 02:30 AM
