Thread: What hose is this???
Results 1 to 20 of 21
  1. #1 What hose is this???
    Dec 2011
    Grand Prairie, Tx
    I noticed today I had coolant leaking from it, not much but enough to run down the back side of my engine.
  2. #2 Re: What hose is this???
    Houston
    Thats a coolant elbow
  3. #3 Re: What hose is this???
    Ohio
    thats your coolant elbow. bout 5 bucks a pack at any auto parts store
  4. #4 Re: What hose is this???
    Grand Rapids, MI
    those are coolant elbows, can be found in the help section at your local parts store
  5. #5 Re: What hose is this???
    Dec 2011
    Grand Prairie, Tx
    Are they prone for going out and leaking like so? Does it really require sealant like there is posted in there picture? or did the previous owner do that to stop the leak?
  6. #6 Re: What hose is this???
    Ohio
    thats the oring that got smashed up.
  7. #7 Re: What hose is this???
    Grand Rapids, MI
    but yes, they are very very common to break, leak, etc.
  8. #8 Re: What hose is this???
    Dec 2011
    Grand Prairie, Tx
    Ah then that would make sense! Thanks! I'm guessing it's pretty easy to replace? Just tug on it and replace it?
  9. #9 Re: What hose is this???
    Grand Rapids, MI
    essentially... getting it out it may break so be prepared to pick plastic pieces out. getting em in. lube em up with crisco or whatever you have and slide it in very gently and let it take it's place in there.
  10. #10 Re: What hose is this???
    Ohio
    you have to take off the alternator/tensioner assembly to get it
  11. #11 Re: What hose is this???
    Dec 2011
    Grand Prairie, Tx
    What the hell?!? Just to get to this hose?? That's insane
  12. #12 Re: What hose is this???
    Grand Rapids, MI
    insane? it's easy. EASYYY.
    work on some other cars and then tell me this is insane. i can do this in like 10 minutes, plus coolant re-fill and bleed time
  13. #13 Re: What hose is this???
    Ohio
    yeah it wat 3-4 bolts? then move it, pull out and clean the holes. lube and put new elbows in. button it back up
  14. #14 Re: What hose is this???
    Grand Rapids, MI
    3 or 4 to get the alternator bracket and alternator off, then 3 i believe to get the tensioner bracket. then pull, then spew coolant, and put it back together
  15. #15 Re: What hose is this???
    Dec 2011
    Grand Prairie, Tx
    Well what I'm saying is you have to remove the alternator just to get to a hose, that's pretty crazy. Never had to do that with any of my other cars.
  16. #16 Re: What hose is this???
    GT Level Member redgtp97's Avatar
    IL
    Its not really a hose its a hard piece of plastic that can break easily. If you tried to do it without removing the alt you would just break the new one
  17. #17 Re: What hose is this???
    Minnesota
    I think thats the coolant elbow.
    It's about 3 to 4 bolts. Pretty easy. lol
  18. #18 Re: What hose is this???
    GT Level Member thegipper's Avatar
    grafton, wi
    First you need to remove the belt. I find it easier to take the belt off by first removing the coolant reservoir. There are two 10mm nuts holding the reservoir down. Simply remove them and lift up on the reservoir and set it aside. Now that you have more room, take a 15mm wrench or socket on the tensioner and take the belt off.
    Disconnect the alternator wire and plug.
    Three 15mm bolts holding the alternator in place, remove those. Set alternator aside.
    Three 15mm bolts holding the alternator bracket in place. Two are obvious, the other one you cant see but you'll find it.
    Once you remove the bolts you can now carefully pull out the coolant elbows and replace with new ones. Heater Hose Fitting | 2002 Pontiac Grand Prix 6 Cylinders 1 3.8L SFI SC OHV | AutoZone.com
    Put a small amount of oil or vaseline on the orings before you put the new ones back in. Doesn't hurt to clean up the holes where they go into either.
    Put everything back on and be done with it.
    Your welcome......
    02 GT - HV3, 3800 Perf. Tuned, Plog, ER rockers, DP w/Magnaflow, CAI, 180* stat, Plugs/Wires, Poly Uppers, Driver mod.....
  19. #19 Re: What hose is this???
    GTP Level Member
    Oct 2011
    Raleigh, NC
    I just got home and car is leaking underneath. Dripping on the transmission pan ,corner passenger side.
    Looks like coming from above, probably elbows, could it be waterpump ? Will be able to see better in morning.
    Leak is toward front of car,dripping above cv shaft forward of shaft.
    1997 Red GTP 182000 miles stock
  20. #20 Re: What hose is this???
    Grand Rapids, MI
    and i've found..if you will just get the elbow partially in the tensioner while aiming it in the LIM hole, get it just seated. then get your 3 bolts started. push the elbow in and keep wiggling it to keep slack in it, and just keep moving it as you tighten it down and eventually it will fit in its spot and be a perfect 90 degree angle. make sure it's perfect or they'll leak again.
  1. PCV hose ID size
    By eclipser in forum 5.3L V8 (LS4)
    Last Post: 06-07-2011, 10:07 PM
  2. What hose is this?
    By dirtmaster88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 06:10 PM
  3. radiator hose
    Last Post: 08-17-2009, 11:11 PM
