Thread: Replacing Tranny and S/C fluid.
Results 1 to 14 of 14
Threaded View
Freebeer187 Replacing Tranny and S/C... 08-17-2008, 11:41 AM
Freebeer187 Re: Replacing Tranny and S/C... 08-17-2008, 12:18 PM
archemedes Re: Replacing Tranny and S/C... 08-17-2008, 12:41 PM
Guest Re: Replacing Tranny and S/C... 08-17-2008, 12:59 PM
Freebeer187 Re: Replacing Tranny and S/C... 08-17-2008, 01:03 PM
Guest Re: Replacing Tranny and S/C... 08-17-2008, 01:06 PM
Freebeer187 Re: Replacing Tranny and S/C... 08-17-2008, 01:20 PM
GR8racingfool Re: Replacing Tranny and S/C... 08-18-2008, 02:09 PM
Freebeer187 Re: Replacing Tranny and S/C... 08-18-2008, 03:49 PM
Freebeer187 Re: Replacing Tranny and S/C... 08-18-2008, 06:46 PM
Reptile Re: Replacing Tranny and S/C... 08-19-2008, 11:41 AM
GR8racingfool Re: Replacing Tranny and S/C... 08-19-2008, 02:34 PM
Guest Re: Replacing Tranny and S/C... 08-19-2008, 02:50 PM
Zef_66 Re: Replacing Tranny and S/C... 08-20-2008, 07:31 AM
  1. #1 Replacing Tranny and S/C fluid.
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    Two questions in this one:
    1. This may be how the car drives, but when im driving the car and give it some gas, it will hang at 4500+ RPM. It takes a few seconds to shift into the next gear and it seams the higher the rpm it is, the longer it takes to shift. Its very annoying. Will replacing the tranny fluid help me at all? Maby my tranny fluid is old? Also none the less the car has no performance increase (stock) from 4500 rpm to red line. Where on the other hand my bro's GTO will rock out the higher RPM you are at(bad example I know...) I think mods will fix this for me
    2. What tool can I make/buy at a store to get the S/C oil out? Im having trouble finding a large syringe to take it out. Any reccomendations would be nice, as its sunday and I have some free time Also how will I know the S/C is full of oil when I replace it? (<----Noob)
    Thanks!
    *EDIT* This looks like a good tutorial : http://www.paulstravelpictures.com/G...nge/index.html
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  1. Replacing Injector O-ring's [*]
    By J_Ferguson in forum How To Write-Ups/Tech Tips
    Last Post: 04-25-2013, 12:48 PM
  2. replacing bad ac compressor?
    By fst in forum Off Topic Discussion
    Last Post: 07-23-2010, 07:51 PM
  3. What Tranny Fluid should I run?
    By Iron Indian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-15-2009, 01:24 PM
  4. Replacing the shifter cable
    By Zef_66 in forum General Tech Discussion
    Last Post: 01-25-2008, 01:12 PM
