Thread: Help with fuel filter
Results 1 to 10 of 10
  1. #1 Help with fuel filter
    SE Level Member Compg4me's Avatar
    Dec 2011
    Grand rapids Mi
    So I decided to finally change my fuel filter on my 04 grand prix. After jacking up the car and getting under there I see that the fitting going into the filter is partially rounded off and I can't get my fuel line wrench on it. Does anybody have any tips or tricks to getting this off? I don't want to round it off more by using a regular open end wrench, definitely don't want to put some vice grips on it if I don't have to.
  2. #2 Re: Help with fuel filter
    SE Level Member jaked1985's Avatar
    Jan 2012
    West Union, Iowa, United States
    Smaller wrench, or vise grip... not a lot of options. You can get a "repair" kit from a parts store that comes with a new fitting, a few inches of line and a compression fitting.
  3. #3 Re: Help with fuel filter
    Ohio
    crescent wrench.
    Dec 2011
    Grand rapids Mi
    I'll try the vice grips then and if that doesn't work then I'll cut the line and use the fuel line repair with the compression fitting.
  5. #5 Re: Help with fuel filter
    Often I'll put vise grips on both that and the filter. Then spin the filter, not the line nut. Works like a champ.
    Dec 2011
    Grand rapids Mi
    So two pair of vice grips and turn the filter clockwise?
  7. #7 Re: Help with fuel filter
    Unhook the plastic quick hose to the filter. Put your vice grips on and unscrew the filter. Filters unscrew counterclockwise..
  8. #8 Re: Help with fuel filter
    Look at the filter straight on from the unhooked end. It'll go counter clockwise. If you stare down the line with the vice grips on it to the filter, then it'll look clockwise. I see what you are saying.
    Take a minute and reason out which way you need. You'll be upside down and possibly backwards.
    Dec 2011
    Grand rapids Mi
    I'll be looking towards the filter, but basically opposite of line nut. Should I put some anti seize on the threads when I put the new one on?
    Dec 2011
    Grand rapids Mi
    Well I finally got around to changing the filter. I got it off with the two locking vice grip method. I wish I would have just cut it off because after spending an hour getting it off and probably pulling a bicep in the process, I noticed that it appeared the line nut looked like the first part was cross threaded. I ended up at the auto store buying the fuel line repair kit that was mentioned with compression fitting. Now I have a new filter with a new line nut that's not rounded out and corroded like crazy plus if I ever have the problem again I can take it apart at the compression fitting. I believe that this fix should last forever because of the fact the compression fitting is all metal with no gaskets or o rings to wear out. Anybody have any experience with these?
  1. Where is the Fuel Filter???
    By Curt63084 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-08-2011, 07:47 PM
  2. Fuel Filter and Fuel Pump 04 Grand Prix!
    By bjornbjorn in forum General Tech Discussion
    Last Post: 04-12-2011, 12:26 PM
  3. Changed Tranny Fluid/Filter, Fuel Filter Tonight
    By nickbuol in forum General Tech Discussion
    Last Post: 10-15-2010, 06:04 PM
  4. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
