Thread: Houston we have a problem !!!
Results 1 to 10 of 10
  1. #1 Houston we have a problem !!!
    SE Level Member PALMCASTER GT1's Avatar
    PALMDALE CA
    Ok , so about three weeks ago I bought a used 06 gp tranny from the wrecking yardand after putting it in I had the wrong gear ratio so I changed in with my old one from my 04 ( BIG DIFFERENCE ) car ran fine for a couple of weeks , now since last friday I noticed a noise coming from the tranny , kind of sounds like an empty power steering pump but only when I would start it in the morning until saturday , now I hear it well driving , until today...I was driving and the car acted like I slammed it in to low and then back to normal until 20 minutes later , I took a turn to avoid traffic and.........NOTHING !!!! Now it won't go in to any gear. My guess is thepump went out , anyone got any ideas???
    04 GT1
  2. #2 Re: Huston we have a problem !!!
    Most likely the pump. Try pulling it down to 1 or 2, if you have nothing, it's probably pump. The pump will whine when it has trouble pulling fluid etc.
  3. #3 Re: Huston we have a problem !!!
    It does sound like the pump but have you checked your fluid?
  4. #4 Re: Huston we have a problem !!!
  5. #5 Re: Houston we have a problem !!!
    PALMDALE CA
    Thanks bio248 , damn spell check.billboost37 I tryed every gear and nothing. I do believe its gonna be the pump.
    04 GT1
  7. #7 Re: Houston we have a problem !!!
    PALMDALE CA
    Hey do you guys think theirs a chance that changing the differential could have made this happen ?? Or just time and wear and tear ??? if it is the pump.
    04 GT1
  8. #8 Re: Houston we have a problem !!!
    St. Louis
    Have you checked the fluid level? Does the fluid look good and red? I could see an extremely clogged filter causing this as well (fluid starvation).
  9. #9 Re: Houston we have a problem !!!
    PALMDALE CA
    But other then that it ran fine until this.
    04 GT1
  10. #10 Re: Houston we have a problem !!!
    PALMDALE CA
    NO !!! When I got the tranny it only had fluid in the torque converter so I put a new and fluid in , it's full but don't go in any gear.
    04 GT1
  1. Another ABS problem...
    By SuperCharged0nE in forum Brakes/Suspension/Chassis
    Last Post: 03-05-2010, 12:55 PM
  2. car problem....
    By hdc80 in forum General Tech Discussion
    Last Post: 08-27-2009, 07:38 AM
  3. DIC problem
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2008, 04:41 PM
  4. How do i fix this problem?
    By thenervemann in forum General Tech Discussion
    Last Post: 11-01-2008, 01:49 PM
  5. well now its a problem...
    By the1euge in forum General Tech Discussion
    Last Post: 10-26-2008, 01:43 AM
