Thread: Seafoam product
Results 41 to 60 of 78
  1. #41 Re: Seafoam product
    Let it suck the can empty then shut it off for about ten min then restart
    SE Level Member Compg4me's Avatar
    Dec 2011
    Grand rapids Mi
    Just did mine today. I bought some 7/32" vacuum line and hooked the one end into the intake under the supercharger snout. I put the other end in a cup with half a can of sea foam and let it suck it dry. The car died just as the cup was emptied. I let it set for 15-20 minutes, then I started it up, after about 3 try's to start she bucked like crazy but smoothed out withing 20 seconds. I took her for a nice drive and beat the snot out of her. The smoke was enough that a car at a red light started honking at me and pointing. Car idles and response seems to have improved dramatically.
  3. #43 Re: Seafoam product
    SE Level Member JcGTP39's Avatar
    Jul 2011
    Grand Rapids Michigan
    but let engine suck it up slow cause it can lock a engine up real quick
    97 GTP. ZZP CAI, ZZP Custom Dyno Tune, Drilled 180* Tstat, Voltege Booster, A104's, ZZP Wires, 3.4 Pulley, ZZP Stainless Headers with TOG down pipe, ZZP 3 inch Stainless Cat Back.
  4. #44 Re: Seafoam product
    Quote Originally Posted by JcGTP39 View Post
    It can't lock up the engine. I just shove the hose in the can and it sucks it dry pretty quick and then i shut the car off.
  5. #45 Re: Seafoam product
    SE Level Member Lawenforcer's Avatar
    Shelbyville, IL
    So I read the entire thread and I am wanting to get everyone's general consensus on what vacuum line EXACTLY that they use for this. Location and maybe a pic of it if you have it. I am brand new to all this and just got my GTP a week ago and was wanting to run it through my lines. Not that the car is running rough or anything it is a 2000 GTP with only has 80,000 miles on it but just to ensure there is no build up in the lines etc...I just don't want to screw anything up trying to do this. Thanks ahead of time., Rich
    2000 Grand Prix GTP
  6. #46 Re: Seafoam product
    there is a t line under the supercharger snout pull that off and hook a vacuum line to it and use that.
  7. #47 Re: Seafoam product
    Shelbyville, IL
    OK, I am going to give it a try. Which hose exactly do you put in the bottle of seafoam? Sorry for so many questions....
    Thanks Rich
    2000 Grand Prix GTP
  8. #48 Re: Seafoam product
    the hose that you connect to the intake manifold under the supercharger snout.
  9. #49 Re: Seafoam product
    Shelbyville, IL
    Ok, thanks for all the help!
    2000 Grand Prix GTP
    The Boss Iceman6669's Avatar
    Jun 2011
    I ran mine through the SC with no ill effects
    2011 F-150 Yote powered
  11. #51 Re: Seafoam product
    I did to but it could cause problems
  12. #52 Re: Seafoam product
    Jul 2011
    I geuss where you run it. I ran my through the brake booster vacuume line.
  13. #53 Re: Seafoam product
    Jul 2011
    I guess it matters where you put it*. I was told that it could lock your motor up of you pour to much of it in the intake
  14. #54 Re: Seafoam product
    Pennsylvania
    Putting any liquid into the cylinders too fast can lock it... although I dont think 1qt spread across all the cylinders would be enough to hydrolock... but best to take it slow imo
    Sport Edition Kv5 18x8
  15. #55 Re: Seafoam product
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    just did it to mine. EXTREME amounts of smoke, even under the hood. It took me a good minute to get the car started. Running better now, pretty cool.
    Jun 2011
    Smoke under the hood prolly means u have an egr or exhaust leak.
  17. #57 Re: Seafoam product
    Jul 2011
    Yeah mine smoked by the EGR didn't seem like it had a leak but must have a small one lol.
  18. #58 Re: Seafoam product
    Oct 2011
    New Jersey
    Its probably a big leak, there was quite a bit amount of smoke. You're probably right though, cause it feels like its not running under full power when i get on it, it seems to lag behind and back/misfire.
  19. #59 Re: Seafoam product
    Jan 2012
    At home
    Is there a full write up with pictures fur us dummies?
  20. #60 Re: Seafoam product
    Minnesota
    I was actually thinking about this the other day. I put mine in my brake booster line but was thinking about the effect of the seafoam in the rotor pack of the blower and internals.
    Putting directly into the intake might actually be better.
  1. seafoam
    By samuelcb409 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-15-2012, 05:55 PM
  2. Seafoam???
    By Iceman6669 in forum General Tech Discussion
    Last Post: 07-17-2011, 11:44 AM
  3. Seafoam
    By BwolfGT in forum Off Topic Discussion
    Last Post: 09-20-2009, 03:54 AM
  4. Seafoam
    By my engine is upside down in forum General Tech Discussion
    Last Post: 06-03-2009, 06:19 AM
  5. Seafoam
    By J_Man55 in forum General Tech Discussion
    Last Post: 08-08-2008, 08:23 PM
