Thread: Seafoam
Results 1 to 8 of 8
  1. #1 Seafoam
    Richmond, VT
    I've never used seafoam on a supercharged car and it has me a bit concerned that running it through a vacuum line will run it through the charger.
    1st off, if it does get into the supercharger, is that a bad thing? I cant remember how volatile the seafoam stuff is.
    Have any of you ever ran seafoam through your vac lines to clean the injectors out, and if so, does it matter on the vacuum line?
  2. #2 Re: Seafoam
    NE Ohio
    GT guys run it through the brake booster lien because it feeds all cylinders, however you don't want to do that on a GTP because it could strip the s/c rotors.
    You wan to run it through the middle vac line that is on top of thew S/C, it feeds all the cylinders but won't pass through the s/c.
  3. #3 Re: Seafoam
    Richmond, VT
    Awesome, thanks!
  4. #4 Re: Seafoam
    GTP Level Member Scimmia's Avatar
    QCA, IA
    um, what? how in the world is the middle line going to be any different than the brake booster like it's right next to? The only line that doesn't run through the SC is on the front of the engine (accessory side) and connects to the MAP, FPR, and BBV solenoid.
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: Seafoam
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    is it even that bad for the sc?
  6. #6 Re: Seafoam
    NE Ohio
    This is the writeup I've always used. Never had any issues with it.
    Grand Prixs Of North America • View topic - Seafoam writeup
  7. #7 Re: Seafoam
    Oct 2008
    Northern Illinois
    I see alot of people saying on there to skip the crankcase step on a high mileage car, im almost to 108K should I leave that part out?
  8. #8 Re: Seafoam
    Medford, NY
    ive never really seen anybody get good results from seafoam.. if they do.. they're usually not sure about it. i've done it a few times regardless.. it's fun lol
  1. Tried Seafoam on my car with no smoke? did i do it right?
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2010, 11:51 PM
  2. Seafoam Query?
    By 03GPGTOWNER in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-11-2009, 12:37 AM
  3. intakes/exhaust/seafoam
    By FtBll Coach in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-08-2009, 10:04 PM
  4. Throttle Body Seafoam????
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-25-2008, 12:42 PM
  5. Seafoam
    By J_Man55 in forum General Tech Discussion
    Last Post: 08-08-2008, 08:23 PM
