Thread: Dyno Results
Results 1 to 20 of 295
  1. #1 Re: Dyno Results
    new britain, ct
    Quote Originally Posted by Just Yourshadow View Post
    Snowflake I had to go bad to make sure your retarded as I think you are. You have absoultely no idea any of the specs of the fuel you run but it's ok I'm going to help your small little brain out. E85 is a 105 octane rating at the 85/15 mix. It takes 30 percent more fuel to get the same amount of energy when running E85 vs. regular gas. Now here's where it gets fun, You live in CT, it's the middle of February, and you wonder why you only have a 60/40 mix. It's because they add more gas to the mix to ease cold starts you ****ing retard.
    someones trying to compensate LMAO
    07 Black GXP.
  2. #2 Re: Dyno Results
    SE Level Member Just Yourshadow's Avatar
    Fox River Grove, IL
    Quote Originally Posted by ctracer View Post
    How the **** am I trying to compensate? I'm sick of people asking stupid questions without doing proper research first. I'm just trying to inform the retards of this information as politely as I can
  3. #3 Re: Dyno Results
    Jan 1970
    Maquoketa, Iowa
    105 is the minimum octane rating which the pumps are required to post for year-round. 85% ethanol blend is around 108-109 octane, the 70% which they should be blended at in winter gets down to 105 octane. The octane isn't that impressive compared to the MON value which is higher for ethanol than typical race fuel and the high MON value is typically where you see advantages in more timing and higher compression. There is a lot of unclear or wrong information out there so hopefully that helps clarify.
  1. GTP Dyno Results!!!
    By OrangeL67 in forum Track Sessions and Kills
    Last Post: 10-17-2011, 11:25 PM
  2. ** Back from ZZP Trip - DYNO results **
    By Silver2kgtp in forum General Tech Discussion
    Last Post: 04-27-2011, 11:28 PM
  3. sexy results :)
    Last Post: 05-12-2010, 08:48 PM
  4. results on the 07 ss
    By joe deleon in forum Track Sessions and Kills
    Last Post: 05-10-2009, 01:06 PM
