Thread: Brand used transmission
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: Brand used transmission
    And here I thought you were having trouble with the language... Who'da known?
  2. #22 Re: Brand used transmission
    SE Level Member PALMCASTER GT1's Avatar
    PALMDALE CA
    @billboost37 , where can I find this thread your talking link??about ?? Can you give me the
    04 GT1
  3. #23 Re: Brand used transmission
    PALMDALE CA
    ok,so check it out,i took my car to the shop to get the differential changed out and the guy tells me it would take a day or two and i didn't have a ride back that day,so i went back to the wrecking yard and asked the guy if he gave me back some money back i would do the work myself and he agreed and gave me $100 back so i paid $400 for a 06 trans .
    so today i did the work with the tranny in the car , only had to take off the tire and trans axel and disconnect the strut and rotor.
    i followed the info i got from BILLBOOST37 to change the differential, i used my original one from my 04 .please note THERE IS A B I G DIFFERENCE IN THE GEAR RATIO ON THE 04, IT'S A LOT SMALLER THEN THE 06, BUT AFTER THE CHANGE MY CAR RUNS GREAT. THANKS BILLBOOST37.i will do a wright up on it later after i get some more pictures, i have the whole job well i did it but need other's to give everyone a good view and how too.PEACE.
    04 GT1
  4. #24 Re: Brand used transmission
    Minnesota
    I thought changing the diff doesn't change the gear ratio of the trans just HD vs Non-HD? Unless you just had a bad diff.
    Edit- Never mind..I saw that you can get a 3.05 final drive diff.
  5. #25 Re: Brand used transmission
    PALMDALE CA
    @pure2sin , after going back to the yard I got the tranny from , I looked at the motor it was connected to they had 06 marked on it and it wasn't s/c , when I put it in, it would shift hard , so I took it to get reprogrammed but the guy said it was the wrong gear ratio and if I just changed the differential it would be fine. So I changed it and guess what.... It runs sweet now !!! And the gears on the 06 were bigger then my original one's from my 04.
    04 GT1
  6. #26 Re: Brand used transmission
    Glad you got it done. However if you pulled a strut and brakes, then you did it the harder way.
    BTW
    http://www.grandprixforums.net/how-r...xle-39805.html
  7. #27 Re: Brand used transmission
    PALMDALE CA
    Well I didn't take them out, I just disconnected them to move the spindle out of the way a little bit, but a screw driver n hammer worked out fine to get the differ out , whole job took about an hour 1/2.thanks for the help bro.
    04 GT1
  1. brand new and need help
    By alaskaGTP in forum General Tech Discussion
    Last Post: 08-24-2009, 02:04 PM
  2. Brand New!
    By LBGPRIX13 in forum Introductions/Noob Questions
    Last Post: 08-10-2009, 09:56 PM
  3. My GTP vs Brand New GTP
    By DesQ27 in forum Track Sessions and Kills
    Last Post: 06-14-2008, 10:22 AM
