Thread: brand new and need help
Results 1 to 4 of 4
alaskaGTP brand new and need help 08-23-2009, 05:30 PM
UR LOSN Re: brand new and need help 08-24-2009, 12:32 PM
Jakegday Re: brand new and need help 08-24-2009, 01:23 PM
Liquifire Re: brand new and need help 08-24-2009, 02:04 PM
  1. #1 brand new and need help
    California
    Was getting an oil change today and the mechanics suggested both my front bearings were going bad. I would like for somebody here to educate me on how to tell for myself if they are bad before I spend close to $1000 (as quoted by them) for replacement. Also, if it turns out my bearings are bad, where I can shop and get service that is wallet friendly. I'm in San Diego. Thanks a bunch.
  2. #2 Re: brand new and need help
    I live here. UR LOSN's Avatar
    Rockford, IL
    Do you hear a grinding noise while driving down the road? are any ofthe ABS lights on?
    if not. they are fine.
    Topic moved to correct section.
  3. #3 Re: brand new and need help
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    i took my car to a shop after doing my front struts for an alignment. they told me both my front bearings were bad and wanted nearly $700. i heard absolutely no noise, no warning lights, everything was great. i took it to a more trusted shop (that doesnt do alignments) for a 2nd opinion and sure enough they said the exact same thing. both wheels have just a little bit of "play" in them. that shop only wanted $500. i am in nebraska though, a bit different then CA
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  4. #4 Re: brand new and need help
    Wausau, WI
    you can jack up the car off of the ground with the wheels pointed straight ahead. With the wheels locked, grab each tire one at a time at the 9 o'clock and the 3 o'clock position. push with one hand and pull with the other. go back and forth. If there is no play, they should be good. If they have play or move more than just a small touch, they are bad..........that is how I do it anyway....Sorry I dont know of any shops in your area.....Sorry............this was for checking ball joints, not the wheel bearings.....
  1. Brand New!
    By LBGPRIX13 in forum Introductions/Noob Questions
    Last Post: 08-10-2009, 09:56 PM
  2. brand quality
    By hotshot in forum Audio, Security & Visual Electronics
    Last Post: 10-09-2008, 11:39 PM
  3. My GTP vs Brand New GTP
    By DesQ27 in forum Track Sessions and Kills
    Last Post: 06-14-2008, 10:22 AM
