Thread: Changing Axle Boots?
Results 1 to 4 of 4
  1. #1 Changing Axle Boots?
    GT Level Member Points70's Avatar
    Nov 2010
    Bellevue, Nebraska, United States
    Can anyone help me out on how to change the boot on the axles. Ive noticed the sludgy grease and found out it was from the boot that has been ripped, and people say if you don't change it fast it could mess up the axles quick. Thanks
  2. #2 Re: Changing Axle Boots?
    Charles City, IA
    Just replace the axle they are cheap. Once the boot is torn dirt gets in and ruins the bearings.
    SMGPFC Two Nipple General
  3. #3 Re: Changing Axle Boots?
    Nov 2010
    Ok I'll look into that thanks
  4. #4 Re: Changing Axle Boots?
    A boot kit used to be about $30-$40 and axles were a couple hundred. Now a days..you can often put in a new axle for less than a couple of boot kits.
    So the question would then be, do you really want to get all greasy and fight with the axle or just replace it.
  1. Spark plugs boots will not budge - grrr....!
    By Elite6 in forum General Tech Discussion
    Last Post: 02-17-2012, 11:42 PM
  2. Source for aftermarket rubber vacuum fittings (boots)?
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-08-2011, 08:21 PM
  3. Tired of IT - CV Boots/Axels
    By japslpr in forum Brakes/Suspension/Chassis
    Last Post: 02-10-2008, 12:20 PM
