Will a 06 tranny work with out problems in my 04???? Please any help !!!
if it's from another N/A car yes. in 06 the GT was supercharged so you would need one form a base modle
unless you wanted to get fancy and swap in the axle from that same car and reprogram your PCM.
@mater , the tranny was on the motor but out of the car , it was not supercharged , the year might be wrong. @matt5112 no axle to swap out but mine. But I would like to reprogram or put a chip in just don't know witch one ??
then the trans should work fine if it was connected to a N/A engine
Tranny up date , so after all the cleaning on the sub frame, motor and tranny , new motor & tranny mounts trans & oil filter a couple of sandwiches from subway , my car is back on the road and so far no problems.total time was 10 hours in two days.so as far as it goes , a tranny from a 05/06 will work in a 04 : ) thanks for the kind words of wisdom guys PEACE!!!!
