Thread: My Ice Box set-up and external PCV catch can
Results 1 to 8 of 8
  1. #1 My Ice Box set-up and external PCV catch can
    SE Level Member kygtp's Avatar
    Oct 2008
    Cincy
    First up, is my external PCV system that I did. One hose leads from just past the TB opening on the GenV to the can and the other leads from the back valve cover, where I have the PCV valve installed there "inline", that lines runs back to the catch can as well. I was think I am getting alot of blow by, since every time I have torn the motor apart, my intake was always pretty oily, and I am thinking that extra oil is messing with my fueling. I could be wrong, but it is worth a shot.
    Some pics of it mounted up:
    For about a year now, I have thought about doing a ice box setup, and I finally got around and doing it, after have bought the cooler over a year ago. This is only for the track and is completely removable, install the passanger seat, to be able to drive the car on the street if I want.
    Anyways, First up, the cooler:
    The hose leading to the back floor board is the drain, which is mounted about 2" from the bottom of the cooler, so that I don't drain out too much water and get air in the intake line. I used a rubber grommet already in the floor board to drain the water, so I used it to poke out a 90* fitting.
    Here is what it looks like under the car:
    The inlet coming in from the back.
    Inlet in the cooler:
    The outlet that leads to the pump, mounted down low to prevent sucking in air in the system:
    Here you can see all three, inlet, outlet and drain:
    Now I took a knock out tool and made two hole in the floor board to lead all the hoses out of the cabin, here you can see how that turned out. The oulet hose, I covered in a refletive sleeve and also covered both hose with a 1" hose to prevent rubbing on the sharp edges of the sheild that it passes by:
    To keep the hose up and out of the way, I ran them next to the oil pan and wrapped them the same way:
    I am going to try and make this short. I am currently running a "open" type of system, so I have a reservior that all the fluid dumps into and then runs to the FMHE, to the pump and to the IC and back around. Now, my cooler acts as my reservior, so I need a way to be able to shut off the reservior in the engine bay, so that the pump, pumps from the cooler.
    I wanted to acheive this by NOT taking hoses off and switching them around, So I used 3 way valves, a total of 3 were used along with one with a "T" and a regular type of ball valve. (Was not able to get another 3 way valve in time)
    Pics of all the valves, I feel like I need a map to make sure I turn them all the right way:
    Here is a couple of shots of under the car, as you can see, I have hoses running everywhere, but you can see where they come out of the floor board, and run around to the driverside of the car to the pump, FMHE and the IC.
    The nice thing is, is we were able to do this without any of the hoses dipping lower than the sub frame of the car.
    Once I am finished racing, and want to put the seat back in, so that the wife and I can go out riding around, I pull out the cooler and connect the two hoses together, switch all the valves to work off the reservior in the engine bay, and we are good to go.
    The result was amazing, I dropped .2 or so off my 1/4 with out any KR what so ever at 22* of timing. In one 1/4 mile, it will melt one 5# bag of ice, BUT my front mount after the run feels like it just came out of the Frig. Very cool to the touch, that is for sure, even on a warm night.
    Well, there you go, and thanks for looking.
  2. #2 Re: My Ice Box set-up and external PCV catch can
    so you have gas in a cooler? or are there coils that are not in the cooler? im lost, looks unsafe. why not just buy a fuel cooler that works with dry ice under the hood? at least you can leave it in and just ice it when you want to.
    and why does this seem like ive seen it before somewhere?
    edit: its for a ic. ok i get it now.
  3. #3 Re: My Ice Box set-up and external PCV catch can
    Oct 2008
    Cincy
    Yeah, that is NOT gas, it is a mix of coolant and water. This was after I first installed it and not all the coolant was out of the system.
  4. #4 Re: My Ice Box set-up and external PCV catch can
    Pennsylvania
    Very cool.
  5. #5 Re: My Ice Box set-up and external PCV catch can
    GTX Level Member Steel Armadillo's Avatar
    Orlando, Florida, United States
    Very cool. Any estimate on the weight added?
    The evil LG8 still refuses to die.
  6. #6 Re: My Ice Box set-up and external PCV catch can
    Buffalo
    its like a giant reservoir. For all the trouble you did to make such an elaborate system, why not utilize a 2nd heat exchanger inside the icebox?
  7. #7 Re: My Ice Box set-up and external PCV catch can
    GT Level Member RegalGS98s's Avatar
    NJ
    Cool mod. For the ball valves, if they get hot might want to use cpvc valves instead, they should handle the heat better. Is that a laptop stand in place of the passenger seat?
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  8. #8 Re: My Ice Box set-up and external PCV catch can
    Oct 2008
    Cincy
    Quote Originally Posted by Steel Armadillo View Post
    I would have to say only around 10# WITH a bag of ice in the cooler, but being able to add timing due to ice water running through the system, I am fine with it.
    Quote Originally Posted by crazyguy03 View Post
    Yes it a giant reservoir. It is all about surface area. If you have a second heat exchanger in the cooler, there is less surface area for the ice to hit, with this setup, as soon as the water goes in, it hit the ice chunks and cools. That is why I put the output to the pump at the bottom of the cooler, to make sure it is pulling the coldest possible water out.
    Quote Originally Posted by RegalGS98s View Post
    They NEVER get hot. After a 1/4 mile run, the water is still COLD, it blows me away as to how well this works. If it is a cool night, there will still be small bits of ice left in the cooler and all the lines running to the IC, are cold to the touch, and the front mount is COLD. And when I pull the cooler out to do tuning on the street, and turn all the valves, there is no fluid running through them. Plus these valves can handle up to 140 degree water temps, so I think I will be fine with them, but good to know though.
    This is how it is all routed:
    Water is pulled from the cooler
    To the pump
    Into the IC
    Out of the IC to the top of the FMHE
    Out of the bottom of the FMHE, back into the cooler
    When the valves are turned off for when the seat is put in it is run like this:
    Out of the IC
    Into the TOP of the FMHE
    Out of the Bottom of the FMHE to the pump
    Pump to the IC
    I hope that makes sence to you, like I said before, when I first installed it, it took me a minute to figure out my own work.
    Yes, yes it is. A friend of mine runs a machine shop and makes them for the local law enforcement cruisers and he had a extra one laying around. So I put a bunch of holes in it on the mill to make it lighter and modded it to fit. Works great.
  1. How to add an external range pnp switch to a transmission
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 09-05-2016, 07:12 PM
  2. external range sensor
    By CRAZYC in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2009, 05:14 PM
  3. External hard drive
    By joshua_arndt in forum Off Topic Discussion
    Last Post: 10-10-2009, 06:39 PM
