The HVAC controls only work when on 5 in my 97 GP. I checked the fuses and they are all fine. Any suggestions what else to check? I am going to a salvage yard in a few days and I am trying to see if I need to grab a replacement or not.
It's your blower motor resistor. Same thing has happened to me a few times. You can find a resistor for about 30-35 bucks tops, and it's not too hard to replace it. There's instructions all over the web for this problem as it seems to be quite common for our GP's.
Do you have the digital climate control or the knobs?
I found this on Google....
tep 1 remove glove box, 6 screws on the hing, compress glove box slightly so inner track wheels are out of slots and remove.
Step 2 go to google images and type blower motor for a 2003 or what ever year your Grand Prix is and you will find a good diagram of what you are looking for, as well you will see a picture of what the blower resister looks like.
Step 3 Now that you know what you are looking at remove the three small screws using a 6mm socket. Now the blower can be lowered and unplugged
Step 4 Look at the google image of the resister and locate directly behind the blower against the fire wall, unplug wiring leading into it. Time to remove the mounting screws, there are three screws but only two are visible. remove the two you can see and ease the resistor out the third screw hole is slotted so it does not need to be removed.
Step 5 install new resistor and plug all the wiring back in, reinstall blower and glove box. GOOD TO BLOW![]()
Please note: The resistor screws are are a little tough to get to but if you use a 5.5 mm open ended wrench it is easiest.
Read more: How do you replace a 2002 Grand Prix blower motor resistor
