Thread: dash lights abs and airbag lights flicker
Results 1 to 3 of 3
  1. #1 dash lights abs and airbag lights flicker
    PA
    I was wondeirng if anyone else ever had this problem. Every once in a while my dash illumination lights will flicker along with the information center and then the ABS and Airbag lights will blink for a few seconds. I've also noticed if it's at night my headlights will go dim for a moment or two at the same time. It's almost like theres some crazy load for a moment or the alternator stops charging for a moment, but why would my dash lights flicker off and on?
    Has anyone ever had this issue?
  2. #2 Re: dash lights abs and airbag lights flicker
    Yoga city
    dimmer switch maybe, never know with the gremlins we got in these cars.
  3. #3 Re: dash lights abs and airbag lights flicker
    St. Louis
    Check to make sure that all your battery cables are clean and tight. I've seen loose cables cause this before.
  1. Head lights and dash lights randomly shut off
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-01-2020, 05:45 AM
  2. Replies: 0
    Last Post: 12-04-2011, 01:48 AM
  3. Dash lights
    By 1996pontiac in forum Visual/Body Modifications
    Last Post: 10-10-2011, 03:44 PM
  4. Dash Lights
    By blarney in forum General Tech Discussion
    Last Post: 10-07-2010, 12:09 PM
  5. Dash lights...
    By Boosted02GTP in forum General Tech Discussion
    Last Post: 03-11-2009, 05:04 PM
