Thread: what pulley can i drop to with each option
Results 1 to 7 of 7
  1. #1 what pulley can i drop to with each option
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    ok so i am looking at getting a ic or meth and wanted to know what size pulley i can run with each setup so right now i have headers 3.5 cone filter 104s 180 tstat and i have 42.5 injectors but not installed so withh a ssic what size and what size for a full size ic, and what size if i run meth. thanks
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #2 Re: what pulley can i drop to with each option
    i was thinking of just a 3.25 or 3.3 with all 3 options except the ssic i wouldnt do 3.25 is this right oh and i dont have a tune but i do have a ls1m scanner
    sold 97 GTP stock
  3. #3 Re: what pulley can i drop to with each option
    maybe 3.2, 3.25.
    Really comes down to how the car likes it and how the tune is.
  4. #4 Re: what pulley can i drop to with each option
    utah
    Gonna need a tune with those mods....fo sho
  5. #5 Re: what pulley can i drop to with each option
    if i did get a tune it would have to be canned no one has a tuner around here
    sold 97 GTP stock
  6. #6 Re: what pulley can i drop to with each option
    Minnesota
    I think you will be able to run a 3.2 with those mods pretty comfortably. Some guys are even able to get down to a 3.0 but would be running less timing and mostly not worth it.
    The above is with a custom tune. With a canned tune it's kinda up in the air but some guys on here or other forums could get you pretty close if you have a wideband and some way of seeing KR.
  7. #7 Re: what pulley can i drop to with each option
    ya i have a ls1m which reads kr fuel trims lt ft injector duty all that and it alows me to log
    sold 97 GTP stock
  1. Pulley drop
    By deejayfb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2011, 10:52 PM
  2. Another pulley drop thread.
    By shiftshot in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2010, 05:21 AM
  3. Should i get a pcm tune for a 3.5 pulley drop?
    By okesongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2010, 02:03 PM
  4. pulley drop 05
    By wlmrt6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2010, 07:51 AM
  5. pulley drop question
    By blwn3800 in forum General Tech Discussion
    Last Post: 11-18-2009, 06:43 PM
