Thread: Trouble getting my Grand Prix started
Results 1 to 8 of 8
  1. #1 Trouble getting my Grand Prix started
    Jan 2012
    Kansas
    One day I went out and my 2000 Grand Prix would not start. It would roll over constantly but would not fire and run. Instinctively I changed the plugs on it, which I found out were factory original and had 235k miles on them. Now It runs fine but it requires being jumped to start. When I go to start it all the lights come on, the dingers ding and I can hear the fuel pump run but when I turn the key everything dies. The lights turn off and it acts like it has no power at all. When I let go of the key the lights come back on. If I hook it up to another car with jumper cables it starts right up no problem and will run just fine. The only thing I have noticed is after I run it for a while a little bit of white smoke that kind of smells like burning rubber coming out from around the middle, front spark plug. Is this just a bad battery or something worse? And what could the white smoke be and how could I go about fixing it?
  2. #2 Re: Trouble getting my Grand Prix started
    Start by pulling the battery cables off the battery and ensuring they are clean and tight when you put them back on.
  3. #3 Re: Trouble getting my Grand Prix started
    GT Level Member thegipper's Avatar
    grafton, wi
    I would definitely check all of your grounds. Make sure they are clean and not corroded. Mine was doing something similar and it ended up being ****ty grounds on the battery.
    02 GT - HV3, 3800 Perf. Tuned, Plog, ER rockers, DP w/Magnaflow, CAI, 180* stat, Plugs/Wires, Poly Uppers, Driver mod.....
  4. #4 Re: Trouble getting my Grand Prix started
    Pennsylvania
    Smoke could be oil on the exhaust manifolds. Commonly leaks out of the valve covers.
  5. #5 Re: Trouble getting my Grand Prix started
    GT Level Member Lenny's Avatar
    Jul 2010
    41 R QR 51938 02935
    Quote Originally Posted by SlowNA06 View Post
    and starts fires
    2007 Grand Prix GXP
  6. #6 Re: Trouble getting my Grand Prix started
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    burning down nearby neighbors house and causing death and destruction, better get it looked at
  7. #7 Re: Trouble getting my Grand Prix started
    Jan 2012
    Kansas
    If the valve cover is leaking is that something I should worry about? The car has 235k miles and it really only needs to keep running for another few months until I graduate.
  8. #8 Re: Trouble getting my Grand Prix started
    Pennsylvania
    Depends on how much you like to worry.
  1. I've got an 05 grand prix and I'm having trouble with the rear spark plugs.
    By learningtoworkoncars in forum General Tech Discussion
    Last Post: 09-16-2011, 10:34 AM
  2. Trouble Spots for the Grand Prix
    By SyntheticShield in forum General Tech Discussion
    Last Post: 03-14-2011, 05:28 PM
  3. Replies: 4
    Last Post: 02-20-2011, 09:46 PM
  4. 04 grand prix radio light trouble
    By sasquatch094 in forum General Tech Discussion
    Last Post: 05-20-2010, 05:55 PM
  5. Trouble shooting windshield wipers on 2007 Pontiac Gran Prix v6
    By titancat in forum Introductions/Noob Questions
    Last Post: 01-16-2010, 03:15 PM
