Double Check the Fuel pump connector, Open the little access door in the back seat, Lift the carpet up, And theres a small door open it up, There is the pump, Unplug it and check the connector for corrosion, I had the same Issue... Pumps Easy to replace if you have to. But the corrosion caused the lead to break on the harness side.
