Thread: If the fuel pump is working.......
Results 1 to 12 of 12
  1. #1 If the fuel pump is working.......
    GT Level Member spider4's Avatar
    Nov 2011
    portsmouth,virginia
    will it be loud enough for me to hear if i have my head in the trunk? My car died out yesterday(ironically just put a much needed fuel filter on). I personally couldnt hear it when i was in the drivers seat. Friend told me that if i put my head in the trunk and have someone turn the key i should hear it. Did this several times and honestly i dont hear anything. Had put new sparks and wires and was getting ready to replace the crankposition sensor. If it is the fuel pump would it just die like that? Is there a fuse i should check? And lastly how hard is it gonna be to replace the pump if i have to do so?
  2. #2 Re: If the fuel pump is working.......
    Nov 2011
    south carolina
    Try removing the fuel cap and listening there while someone cycles your ignition from off to run. You outta be able to hear the pump easily this way. What car do you have?
  3. #3 Re: If the fuel pump is working.......
    Nov 2011
    portsmouth,virginia
    I have the 97 gt. Well i found out it is the fuel pump. I had the mechanic check all the fuses and he also hooked a compression device to the fuel rail and once it reached proper pressure the car started right up and ran even. Soon as he took it off car sputtered and shut off. The irony he told me was that by replacing that fuel filter that had been on the car for so long and there being so much crude in the system and the cold weather caused the pump to seize up. The good news is the new assembly will have the fuel sender on it also and will resolve my issue with the fuel gauge reading improper.
  4. #4 Re: If the fuel pump is working.......
    GT Level Member Brian99SE's Avatar
    Dec 2011
    Cadiz, Ky
    Double Check the Fuel pump connector, Open the little access door in the back seat, Lift the carpet up, And theres a small door open it up, There is the pump, Unplug it and check the connector for corrosion, I had the same Issue... Pumps Easy to replace if you have to. But the corrosion caused the lead to break on the harness side.
    99 Grand Prix SE-Blue CAI, 3.03 GR Transmission, U Bend Delete.
    time to call the exterminator
  5. #5 Re: If the fuel pump is working.......
    Nov 2011
    portsmouth,virginia
    Ok Brian. Ill give it a look. So was that something you had to rewire?
  6. #6 Re: If the fuel pump is working.......
    Waukesha, WI
    i can hear mine standing outside the car
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  7. #7 Re: If the fuel pump is working.......
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Quote Originally Posted by redlinepontiac View Post
    I can hear mine sitting in the car, i usually wait for a second or two before starting to ensure pressurization.
    i know that is not necessary, i just do it
    1997 Red GTP 182000 miles stock
  8. #8 Re: If the fuel pump is working.......
    Nov 2011
    portsmouth,virginia
    Then red mine is definately dead. I just looked up the procedure for replacing it. Im not very mechanical but i got a good idea how to do this, except the part where i have to empty out most of the gas in the tank.
  9. #9 Re: If the fuel pump is working.......
    Dec 2011
    Cadiz, Ky
    You dont have to... http://www.grandprixforums.net/norma...prix-3847.html Scroll down for pictures... But double check that connector, Look in the harness end for any corrosion. I started up my car one cold morning. Getting ready for work, Stood there, Lit a cigaratte... Listened to the car idle. then it started to do a lope and die...
    I was in a hurry, Looked at the pump and pulled the connector. seen it was corroded and the little terminal end inside the connector broke. Stuffed a few pieces of stranded copper wire in it to get it on the road till i could get a harness end.
    You could try swapping the fuel pump relay in the underhood fusebox for another of the same type, Like the AC COmpressor relay. eliminate that.
  10. #10 Re: If the fuel pump is working.......
    Charles City, IA
    Have you checked for power at the pump and checked for fuel pressure?
    SMGPFC Two Nipple General
  11. #11 Re: If the fuel pump is working.......
    Dec 2011
    Cadiz, Ky
    Quote Originally Posted by TheOtherNick View Post
    He stated above for fuel pressure.
  12. #12 Re: If the fuel pump is working.......
    I'm a bit confused by compression device able to start the car up.
    Either way..bad pump, bad sender..enjoy the new one.
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Fuel Filter and Fuel Pump 04 Grand Prix!
    By bjornbjorn in forum General Tech Discussion
    Last Post: 04-12-2011, 12:26 PM
  3. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
  4. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
