Thread: New fuel filter today and now car wont start/stay started
Results 1 to 6 of 6
  1. #1 New fuel filter today and now car wont start/stay started
    GT Level Member spider4's Avatar
    Nov 2011
    portsmouth,virginia
    So many of you know ive got quite a few things that needs work on my 97 grand prix gt. Ive changed out sparkplugs, got new wires, and today had a new fuel filter put in(this was badly needed and it took two days to get it off and was full of rusty fuel). Had been working on getting the crankshaft sensor replaced because the only bad thing the car has done is shut off a few times on its own. I had the codes read on the car the other day and it came back with code PO336,PO401,PO441. Anyway the car has at least been starting right up and running with no real issue other than the random shutdown,however tonite i started it up and while it was in idle after a few normal minutes it started to buck a bit. I put it in drive and seemed to be a bit rough but was ok. Until i had to stop then it started to shutter and shack and puff. I would almost say like a car not getting enough gas or running out of gas(and i will put some gas in it to make sure its not simply out). I also happened to notice that before it shut off the exhaust seemed to be thick white smoke,but even that im not too sure because its cold here and the car always emits alot of exhaust smoke til it warms up.
  2. #2 Re: New fuel filter today and now car wont start/stay started
    Pennsylvania
    Crankshaft position sensor fault... maybe bad connection or bad sensor?
    EGR open? Could this be caused by a CPS issue?
    EVAP canister clogged or gas cap bad/loose/off
    If the EGR is opening at idle, it makes the car sound like it's got a nasty-ass lopey cam. It will also show up on a scanner while the car runs. It should be open 0% at idle.
  3. #3 Re: New fuel filter today and now car wont start/stay started
    Nov 2011
    portsmouth,virginia
    Well at the moment the car is not even starting. Wondering if its the fuel pump as i am not hearing it. It should make a noticable noise,especially if i have my ear in the trunk,right?
  4. #4 Re: New fuel filter today and now car wont start/stay started
    St. Louis
    Yes, you should hear the fuel pump whine for 2 or 3 seconds at key turn. Check your fuses first, then maybe try the fuel pump relay as that is a known issue as well.
  5. #5 Re: New fuel filter today and now car wont start/stay started
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    Def fuel pump if u don't hear it
  6. #6 Re: New fuel filter today and now car wont start/stay started
    Check your coolant level. And check a plug to see if it's wet. I know that sounds seriously screwy. Your a GT with a plastic upper intake known to crack and put coolant into the engine. If you are seeing heavy white smoke and it's not condensation, it's likely coolant from your upper manifold.
    Check asap, because after a little smoke and the engine not running (wet plugs don't toss a spark) next up is hydrolock and thats a bad thing for bearings.
  1. grand prix wont start, fuel pump is good.
    By 1986c10 in forum General Tech Discussion
    Last Post: 12-19-2011, 08:51 PM
  2. Doesn't want to stay started
    By penguinknot in forum 3.4L V6 (LQ1) DOHC
    Last Post: 09-13-2011, 10:48 AM
  3. Can't get the car to stay started at operating temp.
    By afallucco in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2010, 10:20 AM
  4. 2000 gtp wont stay running after start??
    By handymontana in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2010, 06:42 AM
  5. 2000 gtp fuel pump wont run after start up
    By look out in forum General Tech Discussion
    Last Post: 05-16-2010, 05:47 PM
