Thread: Service Engine Light came on
Results 1 to 8 of 8
jwjones Service Engine Light came on 01-01-2012, 11:50 PM
Fivefingerdeathpunch Re: Service Engine Light came... 01-01-2012, 11:52 PM
jwjones Re: Service Engine Light came... 01-01-2012, 11:55 PM
jwjones Re: Service Engine Light came... 01-02-2012, 07:00 PM
boostedcompg Re: Service Engine Light came... 01-02-2012, 07:02 PM
Explicit_Spade Re: Service Engine Light came... 01-02-2012, 07:04 PM
jwjones Re: Service Engine Light came... 01-02-2012, 07:10 PM
BillBoost37 Re: Service Engine Light came... 01-03-2012, 02:41 PM
  1. #1 Service Engine Light came on
    Dec 2011
    Grand Prairie, Tx
    So today my "Parking Brake" light came on so I popped the hood and noticed the sensor that goes into the brake fluid reservoir was hanging out, so I disconnected the sensor and pulled it out of the reservoir, the light did turn off. My question is if I disconnect the sensor would it cause the "Service Engine Light" to turn on? My engine runs great no problems at all
  2. #2 Re: Service Engine Light came on
    prolly not.
    got to like a autozone and get the code scanned to see what it is.
  3. #3 Re: Service Engine Light came on
    Dec 2011
    Grand Prairie, Tx
    I'll just check it out tomorrow at work since we got a scanner. I just really hope it's something small... Not a first good impression.
  4. #4 Re: Service Engine Light came on
    Dec 2011
    Grand Prairie, Tx
    Ran it today at work at found out its the crank position sensor. On my way home from work the light turned off, idk?
  5. #5 Re: Service Engine Light came on
    utah
    replace sensor
  6. #6 Re: Service Engine Light came on
    Omaha, NE
    CPS will intermitantly work before going out completely, get it replaced.
  7. #7 Re: Service Engine Light came on
    Dec 2011
    Grand Prairie, Tx
    I'm buying the sensor this week on Friday, any idea which one it might be? I heard these things will kill your Tranny if you don't replace them.
  8. #8 Re: Service Engine Light came on
    Typically the only issue from a CKPS sensor is rpms on the tachometer dropping off, car stalling. I've never heard of a trans being harmed by a crank sensor.
    It's the one that is located behind the harmonic balancer. Ensure you have 1/4 20 bolts or M6 x 1.00 bolts to pull the balancer. Most puller kits don't include them.
  1. Service engine light
    By dlhome66 in forum General Tech Discussion
    Last Post: 12-18-2011, 08:36 AM
  2. Service engine light
    By s33dl3ss in forum General Tech Discussion
    Last Post: 07-30-2011, 04:10 PM
  3. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  5. Service engine soon light
    By the955iman in forum General Tech Discussion
    Last Post: 02-15-2009, 01:21 PM
