Thread: Am I screwed?
Results 1 to 3 of 3
  1. #1 Am I screwed?
    Dec 2011
    United States
    Hey guys, new here. I'm trying to set up a system in my 99 grand prix. The gauge of wire I'm using is 0. Does anyone know of any holes that run from under the hood into the car? I can't seem to find any. If not do you have any suggestions?
  2. #2 Re: Am I screwed?
    Waukesha, WI
    driver side by cowl, pasenger side by cowl...
    for that big of a wire, make you own hole and use a gromment around the hold, or split vacuum hose in half and use that..
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #3 Re: Am I screwed?
    GTX Level Member bronzemist02's Avatar
    Canada
    ^ This. I ran my wiring through an existing hole in the firewall but with the size you are running it would be better to make a new hole and use a grommet with it.
    02 GT: Silverstar ultras, nighthawk platinum 2157s, ngk plugs, champion wires, 6k hid fogs, stainless magnaflows, cleaned tips, 2 10" subs. Finally painted.
  1. so my transmission is probably screwed
    By grandprixgtsean in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2011, 08:30 PM
  2. I screwed up.... hub nut....
    By Lionel in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2011, 09:11 PM
  3. So did i just get screwed
    By gtp239 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2011, 12:42 AM
  4. Did I get screwed over?
    By cdude20 in forum The Rant Forum
    Last Post: 11-19-2010, 12:34 PM
  5. Screwed?
    By Vegas~Blown in forum Brakes/Suspension/Chassis
    Last Post: 11-25-2008, 11:21 PM
